61 chev 383 LS1 S475 build
I started to do some panel work, Deleting all the trims on the body line on the side of the car. Other than that the plan is just a nice paint job in the same original colour.
great looking setup and thumbs up for doing it yourself will be interested to see the boost levels and power with just the meth !!!! run an s475 myself !!!awesome!!!! cheers
Finally got the thing started, just to make sure everything is ok.
Oil pressure is low and there is a knocking noise down low in the engine.
http://www.youtube.com/watch?v=Huaam...eature=related
http://www.youtube.com/watch?v=K6gIK...eature=related
cheers mate!! Saw your car on here, very impressive!! Awesome times for an IRS car!!! Goodluck with your next upgrade!
#32
I figure this thing requires a decent diff setup. So i got a junk 9 inch for a good price, sourced new bearings, aluminium pinion support and detroit tru trac LSD (31spl). I will also fit billet axles and disc brakes to the rear aswell. Whilst it is out i will replace all the bushes and box in the lower trailing arms.
I am leaving the old 2.75:1 gears in it for now
#34
This is the start of the project when it turns into a 383 LS1. Because of knocking noise and low oil pressure i stripped it down and decided to build it up. I think someone at one stage has fitted a too big of a cam to it as every single intake valve had hit the pistons and all the intake guides were sloppy.
The piston markings
The piston markings
#35
This is when i ordered a Wiseco/K1 stroker kit, Melling HV oil pump, Comp cam/push rods/lifters/springs/MLS head gaskets/head stud kit/main stud kit and billet timing chain
Assembling the block/filing rings etc
