5.3 turbo cam help
Im in process of starting a 5.3 turbo build. Will be running truck manifolds front mount turbo ( Turbonetics 78/68 .96Ar ball bearing with billet compressor wheel). Arp head studs and Katech rod bolts other wise stock engine. Th400 with 3000 stall (Jakes Performance) with 2.73s in 1996 Mustang GT. The weight of the car should be round 3600lbs when together. My question is cam selection. Called Comp Cams and they recommended 226/228 duration 585/588 on 115 lobe which would be a custom grind. They said it should start spooling at 2000 and full boost at 6000 (15lbs boost) Looking to Get 800rwhp. Is this cam in the ball park for my goals. Any recommendations
Im in process of starting a 5.3 turbo build. Will be running truck manifolds front mount turbo ( Turbonetics 78/68 .96Ar ball bearing with billet compressor wheel). Arp head studs and Katech rod bolts other wise stock engine. Th400 with 3000 stall (Jakes Performance) with 2.73s in 1996 Mustang GT. The weight of the car should be round 3600lbs when together. My question is cam selection. Called Comp Cams and they recommended 226/228 duration 585/588 on 115 lobe which would be a custom grind. They said it should start spooling at 2000 and full boost at 6000 (15lbs boost) Looking to Get 800rwhp. Is this cam in the ball park for my goals. Any recommendationsAndrew
That 800rwhp is very optimistic with that turbo, small cubes, and a T400. Good luck though.
I would guess this forum has more of an idea what works in a turbo LS engine than everyone at comp cams combined.
