LS3 Oil Return
I don't like any of those options. On the truck a lot of people tap the oil pan for there return.
Is it possible to do the same with a LS3 on a 2010 Camaro?
I just want to make sure that it can be tapped above the oil level. And, I did not want to remove the oil pan to find out if someone has already been there and done that.
I called Andy at ADM and he said same thing. He suggested I go to Vortech's web site and look at there install instructions as they have it that way. Sure enough they do so I will be following there instructions.
The 2010 Camaro TT 416 should be up and running by the end of the week.
With a top mount supercharger or turbo you can't do that because it gravity feeds but since I am using an oil return pump will I be ok?
I will be using the Exa-Pump instead of the supplied one.
