looking for realistic expectations; 370 TT
LQ4 Block bored .030 over
Stock Crank
Eagle Rods
Wiseco -11 4.030 pistons
Stock 317s
VTC 3 Cam
ported LS2 intake
Air will be provided via twin TC66 with .58 AR (may need bigger housings, .96? ), A2A IC, JGS WGs and BOV. Fuel will be pump/meth (91 oct and VP M1), e85 would be tooo much trouble. Moser 9, 3.00 gears, TH400, stall is being spec'd by builder.
What should I realistically expect, from my readings 650-700 rwhp seems feasible, is this right?
but I can get bigger housings if need be. E85 is tooo scarce in Los Angeles and I like to drive. The only way I can run it is to have two tunes, one for 91 and one e85, and the e85 would only be used for night time activities. & I want run at least 18 lbs
but I can get bigger housings if need be. E85 is tooo scarce in Los Angeles and I like to drive. The only way I can run it is to have two tunes, one for 91 and one e85, and the e85 would only be used for night time activities. & I want run at least 18 lbsand thanks for the replies, I've combed both of your threads time and time again, nice to have some local folks get to me
