44mm Wastegate on a S475?
Old Dec 11, 2011 | 09:20 PM
MattSapp95_T/A's Avatar
Default 44mm Wastegate on a S475?
Will a Tial 44 gate work on this setup with a S400-75 1.10ar T4
Looking to be around 10lbs plus boost 9.1 compression open down pipe dumped gate
Thanks
Matt
Old Dec 12, 2011 | 12:36 AM
black98ws6ta's Avatar
What size motor?
If you made the wastegate location priority better it would for sure.
Old Dec 12, 2011 | 03:53 AM
SirNemesis's Avatar
I'm running an S475-1.10T4 with a Tial 44. 390ci and no problem.
Old Dec 12, 2011 | 10:05 AM
Hank Peabody's Avatar
The wastegate pipe looks just like a ***** in that picture, I feel like Im back in prison.
I run a 44mm Tial with a PT76 and it will go down to 4#. I havent tried any lower, but it should be good on an S475 down to the same.
Old Dec 12, 2011 | 10:50 AM
Ok great I am going to go with the 44 and see how it does.. I have a 60mm newgen hp currently but dont wanna go through the hassle of having a bigger pipe welded in...
So I'm gonna sale my Turbonetics Newgen HP and go 44 and if that gives me probs I will go with twin 38s...
Old Dec 12, 2011 | 07:42 PM
turbocamaro125's Avatar
had a s480 1.32 t6 and tial 44 with 8.6spring and held great at 9psi this was on 346 ls1
Old Dec 13, 2011 | 03:31 PM
I wonder how much difference it would make on a 370 or a 408?
Old Dec 13, 2011 | 08:10 PM
I built a buddies car ls 383 with a s472 and tial 44mm and it held great on 5psi so id say 408 would work ok....but any big turbo and you want wanna use 2 gates or one big one to control under 10psi
Old Dec 14, 2011 | 06:39 PM
Well anyone wanna trade a 44mm for a turbonetics newgen hp?
By Brett Foote | 2026-06-04 05:00:17
