Need turbo suggestions - Pros and vendors
Ok getting things together finally. Hope to put this thing together over the holiday break. I have a built 9.1:1 comp LS1 with A.R.E. stg 2 heads, vic jr and a virginia speed VTC 2 cam that will be running E85. I'll be putting a truck manifold kit on it that used to have a mpt76 turbo with it. I'd like something similar turbo wise (t4 obviously) that will spool decent and eventually when I turn up the boost get ~1000 crank hp. The MPT76 with this kit made about 620whp/690wtq at 13psi on a broken stock motor (low comp one cyl), so the kit should work well and when well set up, should be a low ten/high 9 car.
What do you think? Suggestions?
