real world data of air to air intercoolers. (flow)
So if my intake manifold sees 25 psi and my turbo is pushing 35 psi the intercooler is blocking 10 psi. But I need to look at it as total air mass? So a rough example If the engine sees 100lbs of air mass and the turbo is making 120 lbs air mas the ic is robbing me of 20lbs of air. More lbs air means more power. But in order to see if the ic is blocking air flow I need a boost gauge on the turbo to compare the differances
