going boost
Old Dec 15, 2011 | 11:50 PM
Reno's2fastestfbodys's Avatar
Default going boost
so for awhile now i have been looking at different kits and set ups and doing my research for a bit its looking like I am either going to be looking for a D1SC or (most likely) buying a (starter) ebay turbo kit. the rear mount seams as if there is quite a bit more modding involved (than anything else will be) so heres the question....
1) I have read that the included turbo (in rear mount) is junk... so replace immediately or work out kinks with it as to not damage a good one?
2) maybe the guys at modular can answer this what all is included in their kit for a grand?
3) screw it and save my $$ for D1SC?
I have read a few of ya'lls build threads the one in Alaska is interesting!!! and GOT to keep that garage CLEAN!!!lol. so input? advice?..... kit recommendations? this will ultimately be topped off with a 6.2 iron (after a blown up LS1).
Old Dec 16, 2011 | 12:16 AM
jt76's Avatar
Don't mess with a rear mount. Most people who have had them and made the switch will tell you not to waste your time. I suggest you look into a KYTP kit if you are set on going turbo.
Old Dec 16, 2011 | 10:23 AM
Adam123's Avatar
Get truck manifolds and build your own front mount!
Old Dec 16, 2011 | 11:54 AM
audacious nick's Avatar
ASSuming On The Tree
There are hot sides you can buy on Ebay for like 500 dollars. Hell, I saw one for 270 about a month ago.
You can run that, or build your own.
Old Dec 16, 2011 | 09:56 PM
links?
Old Dec 18, 2011 | 10:30 PM
SUPERMAN_00TA's Avatar
I say save and go for the D1SC..... Less headache!!
Old Dec 18, 2011 | 10:40 PM
ws602's Avatar
Twin Kytp kit that retains A.C!! Call josh he will hook you up!!
Attached Thumbnails going boost-2109169240047301034s600x600q85.jpg-turbo.jpg   going boost-2825209480047301034s600x600q85.jpg-turbo2.jpg   going boost-2865662910047301034s600x600q85.jpg-turbo-5.jpg
Old Dec 19, 2011 | 12:24 AM
http://www.ebay.com/itm/GODSPEED-97-...item58914c46bf
http://www.ebay.com/itm/97-02-ls1-ca...item45fa42a801
http://www.ebay.com/itm/LS1-97-02-Ca...item1e65057006
Old Dec 19, 2011 | 08:19 AM
NemeSS's Avatar
I got one of those ebay ss fbody kits fs in houston. Never ran. Just mocked up.
300$.
Old Dec 19, 2011 | 10:05 AM
That's pretty good, especially for a budget starter.
Old Dec 19, 2011 | 07:44 PM
300$.
pics to gotcamaro.com
Old Dec 19, 2011 | 08:11 PM
MikeFSKSpeed's Avatar
If you decide to go with a procharger, let me know, I can save you a few hundred bucks on new kits.
Old Dec 25, 2011 | 06:38 AM
Droptopws6's Avatar
PM sent to you Mike
Old Dec 26, 2011 | 08:52 PM
ModularTurbo's Avatar
$799 bolt on kit fits like a glove and no radiator stand up.....
Forward Facing turbo kit includes motor mounts, hotside, and down pipe.
All on the stock K member too..
http://vtsql.gkvbf.servertrust.com/F...it-p/cbrll.htm
