Built 348 Twin turbo sizing
Old Jan 26, 2012 | 03:59 PM
hellbents10's Avatar
LS1Tech Sponsor
Harlen was running a reg ol ls1 block in that car if I remember right.
Now just run bigger fasteners and better heads. Warhawk, LSX, RHS....
Old Jan 26, 2012 | 10:28 PM
505OUTLAWZWS6's Avatar
I bought precision billet wheel 62-66's in a t4
Old Jan 26, 2012 | 10:32 PM
Here is my build thread. I will be updating daily as my plans are to make it to tx2k12 in 6 weeks.
http://truestreetcars.com/forums/pro...rbo-build.html
Old Jan 27, 2012 | 01:46 AM
Fbodyjunkie06's Avatar
hell yea do work!
Old Jan 27, 2012 | 12:14 PM
Louis's Avatar
Do you know the guy that had the white 4th gen with them upsidedownpipe with a tip down 98? Owner was a cool guy. Downpipe fell off, hennessy ended up welding it for them. That car pushed water too....
Old Jan 27, 2012 | 01:07 PM
Sean Stanford at Solidtech Performance. He got first and I got second in the street class last year.
Old Mar 26, 2012 | 08:48 AM
Woody73z's Avatar
Ive got the same turbos about ready to fire it up... Its a built 370ci with 1/2 in head studs and a half filled block. These turbos should put down some good numbers at the track!
Old Mar 26, 2012 | 06:31 PM
Danny's Avatar
Any updates???
Old Mar 26, 2012 | 07:36 PM
venom ws7's Avatar
Great choice setup looks great too..
Can you please PM the price and where did you buy them?
Old Mar 26, 2012 | 07:41 PM
LSevil1's Avatar
I believe Justin made over 1100whp at 23#'s corrected and took second in the street class at TX2K12. That car is mean!
Old Jan 13, 2021 | 09:16 PM
Bluto2010's Avatar
Default Turbo sizing and backpressure on ls3
I have a 2010 camaro ss. Its a sbe ls3, m6, btr stage 4 na cam, arh longtubes and 3.91 gears. I am planning to use either an agp or huron speed twin turbo kit. Both kits have 2.25 inch hotside connection pipes and agp uses a t3 housing and huron uses vband housings. Because of the cam and gearing, i need to keep backpressure as low as possible. I will be using equal length shorties as opposed to stock manifolds as a means of reducing preturbine backpressure. My question is should i fabricate 2.5 or 3 inch connection pipes for the turbines or would 2.25 be enough and will a pair or 6266 .82 ar turbos be sufficient to keep backpressure at a minimum. The car currently peaks around 6800 to 7000 rpm.
