850-900 rwhp front mount truck manifold 78mm turbo
Im almost ready to start on my new build and wanna go the truck manifold front mount kit with a 78mm turbo so how many of u guys are running this set up and what power level are u at and what is your setup via motor turbo heads cam and fuel system and is 900rwhp atttinable with this turbo setup
There may be 50+ threads but I havent seen anyone make 850 900 whp. But everyone is using tc 78mm I haven't seen anyone use any of the race units. I'd like to know what is the best 78mm turbo to make big power. Like 850+ if it's even possible.
You'll have a better chance using a 5.7 or smaller bore to meet your goals. Larger CI engines will most likely max out a 78mm before 800rwhp.
The following users liked this post:
Tonymaez (07-28-2020)
Precision 7675 (76gts) is not much bigger than a TC76 at all. About 1/2" bigger diameter on the compressor cover and the same size on the hot side. The GTM and Super T have the same issue as the TC units, the 68mm exhaust turbine wheel is restrictive. The precision unit is hard to beat for it's size but it's not the most powerful 76mm. That would probably be a GT 4776 style turbo or the new bw 476.
Here are two m6 cars with a PT76, one is 15.5lbs and the other is at 18lbs.
