I need help with A/R and Wastegate size
Car will rev to 6500 and will have a 3400 stall. So the question is
What A/r for 76mm and What wastegate if I want to lower to around 8psi?
Is a 38mm ok, or will I need to go with a 44mm for the lower boost?
TC76 Ball bearing, .81A/R T4 housing 3" DP flange
I debated going with a .84 or .96 A/R
you could easily do a T72 or TC72 (only ~1.5" difference in housing size roughly) TC being smaller.
thanks!
Joe
If other info is required for some to help let me know I will try to get you what I am thinking.
Either that, or the turbo(s) is/are too small for the motor.
the only thing i can say is dont fall into the trap of building for someting you will never need..
.96 TC 76 will do what you want and will be easier to sell than a 72.
6500 and 3400 stall makes it seem like will want bigger.....more like a GTS or S475.
