turbo guys making BIG power on pump gas? lets see the combos and tune..
On my old 364 ls2 made 690 rwhp on a mustang dyno, unlocked with 4l80
8.5cr 225 TFS heads small can. Ls6 intake. APS twins W/lg turbo at 16 psi. 18 degs of timing
Car went 9.96 on 13 psi and a 1.68 60 foot
im not really asking for dyno numbers like some are asking but its nice to hear the numbers. i asked who was making big power on pump gas. going in the 9's at full weight on pump gas is making some big power.i looked in history and did not find any specific threads on pump gas and what people were running...keep em coming guys
What I meant about the track and dyno being differant with pump gas is... On a dyno you only do a quick 3 sec pull with out real world load. So you can make a lot of power and not blow your engine up. You bring that car to a track on a hot day on pump, hot lap it and melt a piston.
My point is that don't think that just because you were ok on a dyno that you wil be ok at the track on pump gas
Ahhhh **** your right. I have a Dyno video he isn't running Meth or nitrous on these pulls according to the description.
http://www.youtube.com/watch?v=7CAIy...e_gdata_player
does e85 count?
My buddy had an LS3 with stock crank, forged rods/pistons, ported LS3 heads, stock LS3 intake/TB, GTS76 turbo with custom wheels, and made 960rwhp on 14psi.
Launching off idle with a smaller TC78 turbo and granny shifting it went 10.01@148mph with a 6speed. The car weighs under 3,000lbs. Its an RX-7. With the new turbo it should run 160mph+ I would imagine on full tilt.
I used to have a tune that made right at 1100 rwhp at 15 lbs of boost on 93 octane pure, no meth. That was when I still had a T56. This was with 11.3 AFR and 16 deg of timing. That same boost and timing on my current TH400 on the exact same motor now makes 890 rwhp LOL
but T56 didn't last more than 1 day at a time on that setting, and Th400 has been living for 2 years now under 26 lbs of boost
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#32
http://www.stevemorrisengines.com/ra...p-gas-must-see
Saw this a month or so back when they did it, about fell out of my chair when I saw what it made.
#33
#34
#36
keep em coming i know there are more out there that have taken some cracks at the strip on some pump gas and low boost....unless they figured out a way with pump gas and high boost that does not include meth or 7.1:1 lol. i did get a hold of tirefryin_s10 about his car and it was interesting boost and timing numbers but would love to see more setups.
#39
#40
No track times yet but 11.5-11.8 AFR, 91 octane no meth 922 whp spinning out on the rollers on a very mild tune at 18#'s.
SPRAYED 01 is right though, I won't run that at the strip without some c16 or some meth at least, being this is my daily driver.
some details in sig. Good thread!!!
Tim.
Tim.
