LSA/LS9 heads??
Old Dec 28, 2011 | 04:12 PM
Rickys S/C Z28's Avatar
Default LSA/LS9 heads??
Have any of yall ever used these head with big boost? I think they would be bad ***. with the way there casted as well as i have read they have a thicker deck.? any info ? or am i going to have to be the ginny pig
Old Dec 29, 2011 | 02:25 PM
nothing?
Old Dec 29, 2011 | 02:30 PM
JAX04's Avatar
I can only think of one person on here thats using them, Rotary1307cc, he seems to like them.
Old Dec 29, 2011 | 03:08 PM
tim99ws6's Avatar
What do you consider big boost.
Old Dec 29, 2011 | 04:01 PM
67RSCamaroVette's Avatar
They have about a 3/4" deck and ports are nearly identical to L92/LS3, except for a little casting in the intake runner to swirl the supercharged air.. I plan on running them as soon as possible, although i'll cut out the little blip in the runner.
Old Dec 29, 2011 | 04:15 PM
tim99ws6's Avatar
That's correct. They are also made from the higher end alloy that the c5r heads are. The ls9's have a 12mm head stud hole as well. Also ls9's have a titanium intake valve.
Old Dec 29, 2011 | 06:56 PM
20lbs plus
Old Dec 29, 2011 | 06:57 PM
Good info. thanks
Old Dec 29, 2011 | 07:59 PM
tim99ws6's Avatar
Originally Posted by Rickys S/C Z28
20lbs plus
All. Day. Long.
Old Dec 29, 2011 | 08:42 PM
NemeSS's Avatar
I didn't think they had such a thick deck for an oe casting.
Has this been confirmed?
Old Dec 29, 2011 | 11:32 PM
westtexasbuff's Avatar
They are 68cc as cast, but can be worked on to get a bigger cc. They are a high-strength casting made of A356T6 alloy, for greater heat resistance, manufactured using the roto-casting method (like the LS9 heads) to virtually eliminate porosity.
They are a great head for turbo!!! I plan on making upwards of 1000whp with mine.
Here are mine after I had them hand ported. We took out most of the swirl wing, but left just a bit to help with atomization.
Old Dec 30, 2011 | 05:54 PM
PRAY HRD's Avatar
does anyone know what the minimum bore size needed to run these is? and i hadn't heard anything about it being a 3/4" deck but definitely the better alloy. Would love to get deck thickness confirmation as well.
Old Dec 30, 2011 | 06:18 PM
NemeSS's Avatar
Yea, I read about toto cast and better alloy feature, but this is the first I've heard of the .750 thick deck. That's awesome if so
Old Dec 30, 2011 | 08:44 PM
I looked it up and it appears I was mistaken. LS9 heads are marginally (only a few thousandths) thicker than a LS1 deck..
