procharger bypass
Old Dec 28, 2011 | 09:23 PM
sharpshooter's Avatar
Default procharger bypass
How do you know when it is time to upgrade from the normal black procharger bypass?
My D1SC has small amounts of procharger oil coming from the bypass.I recently did a pulley swap and see about 14# at my high shift points.I don't know if my bypass isn't keeping up and putting stress on the seal or the seal is just wearing out.What's odd is the oil level really hasn't gone down in the blower though[there is no pcv hooked to the blower].
Old Dec 28, 2011 | 10:02 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
At 14 psi I would upgrade from the Proflow to a larger bypass valve. Hard to say if it will help with your oil seepage but it certainly can't hurt. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Dec 28, 2011 | 10:09 PM
Bob- How much boost do you think the normal proflow valve can handle?
Also are the proflow bullet bypass's a good upgrade over the standard style like I have?
Old Dec 28, 2011 | 10:16 PM
9sectruck's Avatar
if you dont hear in chater when you let off it should be good but it probably could be upgraded
Old Dec 28, 2011 | 10:29 PM
I don't hear a chatter when driving but I can get it to chatter if I rev it in neutral.Does the neutral rev chatter mean anything?
Old Dec 29, 2011 | 04:45 AM
LS1Tech Sponsor
The Proflow is normally good up through 14 psi or so, you're on the borderline. The bullet valve isn't going to give you the additional flow that you would need. Bob
__________________
Old Dec 29, 2011 | 08:25 AM
thanks- Bob
Old Dec 29, 2011 | 08:59 AM
MikeFSKSpeed's Avatar
At that point you should beusing the Big Red Valve - Let me know if you need a deal, I have a special going on them right now.
Mike
Old Dec 29, 2011 | 11:14 AM
LS1Tech Sponsor
Thumbs up
thanks- Bob
You're welcome. I sell them at the link here. http://shop.brutespeed.com/ProCharge...alves_c347.htm Give me a call for a price better than what is shown. Thanks. Bob
__________________
Old Dec 29, 2011 | 12:37 PM
Quick's Avatar
U may actually pick up a few #s with the Red race valve. I did.
Old Dec 29, 2011 | 01:17 PM
LS1Tech Sponsor
That can happen if the ProFlow valve isn't closing off as far as it should. There will always be an air gap when in the closed position, but we once had one that was not closing far enough, and we picked up two psi by swapping the valve out with another ProFlow. Bob
__________________
