Is it worth to upgrade from LS6 intake to a FAST Intake?
Old Jan 1, 2012 | 01:42 PM
98BLOWNZ28's Avatar
bob from brute speed built a nasty 402 ctsv with an f1 procharger. and if im not mistaken, the owner switched intakes from an ls6(it might have been an ls2, dont remember) and picked up around 40wheel/torque. i dont remember the exact numbers, but yeah. its def. possible to pick up more power. i will admit though, its hard to compare considering its a big blower, and a stoker motor.
Old Jan 1, 2012 | 02:13 PM
lmt0705's Avatar
It was an ls2, which is a terrible design
Old Jan 1, 2012 | 03:21 PM
98BLOWNZ28's Avatar
The ls2 may be a terrible design, and I don't want to make this a ls2/ls6 manifold debate, but I think the ls2 can hold it's own. I think it's good competition against an ls6 when it's ported. 90mm tb vs. 78mm, can be ported etc. I've seen ls2 manifolds on motors that make 1000wheel.
Old Jan 1, 2012 | 07:24 PM
eb02z06's Avatar
Originally Posted by FrankieD
I'm starting to get things ready to go FI this spring and I'm wondering if it's worth upgrading from Ported Stock TB/Stock LS6 intake to a: Fast 90/90, Fast 92/92 or a FAST 102/102 setup. I will be using ported 317 heads with my D1SC setup. Cost for upgrading ranges from $1000 to $1400. Will I notice any significant HP increase by stepping up to any of the FAST setups?
I didn't have much luck with the FAST 102 so I put the LS6 and ran the number in my sig. looking for 8.50's next season in the same full street trim.
The FAST should of worked but it didn't, keep the LS6-looking at your sig-get a better cam suited for the blower.
Old Jan 1, 2012 | 09:12 PM
phatasp's Avatar
Originally Posted by allout06
Y did u only make 575rwhp on 15psi? I made 571 on 5.5psi. we're u on a mustang dyno? I figured Ud be makin 650ish already
Yep,mustang dyno through 9in ford and 4l60. And I figured I should be at 650hp too.the iat,s were getting up there and was pulling timing and through pretty crappy exhaust, but it,s about the same hp as when I was running 11psi. So I think a fmic would probably be my next project.
Old Jan 2, 2012 | 01:00 PM
allout06's Avatar
ah ok thats the deal then. ud probably put down 630ish on a dynojet.
i got my fmic on ebay, and it works great. and its only $255 shipped.
Old Jan 2, 2012 | 01:10 PM
NemeSS's Avatar
Keep ls6.
I've seen 680rw thru ls6.
I will be using a ls6 intake over my originally planned fast 90. I don't have to perform any prep work on a stock ls6 intake. Fast requires extra prep work for proper sealing under pressure
Old Jan 2, 2012 | 06:13 PM
phatasp's Avatar
Checked out your set-up,looks nice! definately something to think about.
Old Jan 2, 2012 | 06:20 PM
I8UR4RD's Avatar
Take a look at AFSTYK_____?'s post. he had one and it wasn't worth a ****. he went back to ls6 problem free. I have read into this plenty, and if your going to spend the money on the fast just to get the most you absolutely can out of the car, then why not just go ahead and have a custom sheet metal intake? I mean its and expensive intake to begin with unless you get it from classifieds on the low low. Have it painted and put the money into steak and shrimps.
Old Jan 2, 2012 | 06:22 PM
allout06's Avatar
Checked out your set-up,looks nice! definitely something to think about.
thanks man i appreciate it. PM if you want the link to where i got the FMIC.
Old Jan 3, 2012 | 04:46 AM
stevieturbo's Avatar
And is there any proof these are of benefit ?
Old Jan 3, 2012 | 09:37 AM
  #32
93camaro_zzz's Avatar
Originally Posted by subarubill96
people have gone 8's on the LS6 manifold. Put your money to work elsewhere IMO.
Agree!
Old Jan 4, 2012 | 06:12 PM
  #33
johnny walker's Avatar
what throttle body you running on your ls6 intake.
Old Jan 4, 2012 | 06:25 PM
  #34
what size T/B YOU running on your LS6 INTAKE. I have a stock LS1 with a procharger. not looking to drag race. would like to put a ls6 intake & throttle body. makes 448 rwhp on 6lbs boost. maybe pick up a few more H/P.
Old Jan 5, 2012 | 08:29 AM
  #35
lmt0705's Avatar
im using the stock one still
Old Jan 5, 2012 | 12:04 PM
  #36
Stock TB is more than enough.
Old Jan 5, 2012 | 01:05 PM
  #37
vicouSS00's Avatar
I am curious as to how much I would pick up if I switched to a FAST 92/92 setup and got rid of my ls6 intake/ported tb setup. I remember a few years back when I had my N/A 408 I went from a ls1 intake/tb to a FAST 92/92 setup and picked up 51 RWHP. My current 408/F1-A setup has the ls6 intake setup and while I don't think I would see the same gains I do believe it would pick up some HP and lose a couple lbs of boost. Just can't convince myself the extra $1,000 is worth the HP when there are other cheaper ways to pick up HP in the FI world etc..
Old Jan 5, 2012 | 01:14 PM
  #38
If you can find some genuine back to back tests where people have seen gains under such circumstances, then it may be worth doing.
The LS has been around for many years now.....you'd think if those tests existed, FAST or people selling them would be shouting off the rooftops.
Nope...I dont hear anything.
Old Jan 5, 2012 | 01:18 PM
  #39
Rickys S/C Z28's Avatar
not sure if it has been posted but here is my take on this...folks have been 8's on a ls6 folks have been 8's on a FAST. both are good intakes but both are harder to tune. look at most of the boosted motors that are or have been hurt....number 7 is almost aways the hurt one. this is because the intake design. If i were going to spend the money for an intake i would do a vic jr and an elbow with a ported stock tb. it makes things easier to tune as well as gives you more power up top....plus its the coolest looking intake every IMHO...thats not a custom
Old Jan 5, 2012 | 01:24 PM
  #40
vicouSS00's Avatar
Do you guys truly believe this vic jr style intake would make more HP then and ls6 or FAST setup? What do them vic jr intake/tb setups cost btw? I never have looked into one before.
