oil feed and drain
Old Dec 30, 2011 | 11:12 PM
a4ls2goat's Avatar
Default oil feed and drain
where are you guys tapping the oil pan for feed and return for a turbo setup? pics would be great.
i found this for feed, what do you guys think?
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
Old Dec 31, 2011 | 01:26 AM
Wicked69's Avatar
That is the feed I am using. So no picture required. I tapped mine with -10 fittings right in front of the oil pan by the balancer. Most thought the balancer would get in the way but it doesn't. I used a 90 on there and it slopes oh so slightly but will drain with no issues.
Here are some pics.
Old Dec 31, 2011 | 12:02 PM
a4ls2goat's Avatar
thx for the pics man.
ive heard some people put the drain on the timing cover. Thats alot easier than pulling the oil pan.
Old Jan 1, 2012 | 03:53 AM
ModularTurbo's Avatar
Oh yes CBR oil block FTW
Old Jan 1, 2012 | 09:55 AM
Firehawk441's Avatar
The CBR oil block sold through Modular Turbo is a nice piece.
https://ls1tech.com/forums/attachmen...t-100_1297.jpg
https://ls1tech.com/forums/attachmen...t-100_1298.jpg
https://ls1tech.com/forums/attachmen...t-100_1296.jpg
Old Jan 1, 2012 | 06:10 PM
Wicked69's Avatar
I agree. My oil pan wasn't on yet so I went this route.
Old Jan 4, 2012 | 10:12 PM
a4ls2goat's Avatar
What size feed do you guys recommend? -3 or -4? Journal bearing Turbo.
I know -10 for return.
Old Jan 5, 2012 | 07:12 AM
-4 if you are going to use a filter or restrictor
-3 if not
Old Jan 5, 2012 | 07:28 AM
a4ls2goat's Avatar
-3 if not
Thank you!
Old Jan 5, 2012 | 09:27 AM
dville_gt's Avatar
-3 if not
does this apply for a large frame t6 turbo? i am running a -4 feed with no restrictor with a -12 drain and haven't had a problem yet.
Old Jan 5, 2012 | 09:58 AM
willizm's Avatar
The feed I used that port right above the oil filter that most use. Just drill it out and tap it out. return I had a guy that can weld on the bung
Is that CBR just for a feed or is it a return as well? That thing is pretty nifty.
Old Jan 5, 2012 | 10:01 AM
No that was for T4 turbos
T6 setups usually are -4 feed and -12 drain
Yes the CBR oil block is for feeding the turbo not draining
Old Jan 5, 2012 | 10:58 AM
Sarg's Avatar
Anyone used the Dirty Dingo piece? Looks pretty nice, and at $24.95 it is pretty reasonable in price!
