New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!
Got the new comp 8079mm on the dyno at speed inc. At about 17psi using a 50/50 mix of 93 and 110 is made 777whp and 787ftlbs. This is on a 9.5 370ci with ported 241s and a 232/236 cam.
Running through a locked 4l65e and a moser 9inch with 325 gear.
I'll post the graphs tonight.
I'm very happy with the results, car picked up 100whp going from the tc78 347 to this turbo and engine.
Thanks comp, speed inc and finish line transmission.
Yes I had a back pressure issue with the first 80/79mm. It was 4:1. Comp stood behind their product and sent me a revised one. They said all they did was change the design of the comp wheel. Either way world of differance. I didn't measure back pressure this time but a 10lbs spring did 9psi so its probably not that bad. I was loosing about 4psi through my crappy ebay intercooler. I think that would bring me in the low 800whp range.
http://s124.photobucket.com/albums/p...103_142325.mp4
Sorry for the shitty video, I did it on my phone. But this was the 777whp run.
I can't really go there due to no cage, I go to byron now. Hoping 2012 will finally bring me a 9 second run. I have full suspension and qa1s launching off a t brake this time and 100whp more then my 10.4 run.
So was the old turbo t4 and is the new one t4?
My 87mm turbing 1.25 ar t4 bw was at 1.4 bp at 13 psi boost. I ran the same times on 15psi as I did 25psi.
I also have a ebay air/air what size is yours?
Yes its a t4. I'm not sure what bp is on this turbo. Il do some testing in the spring. I'm sure its less than my 348 tc78 at 16psi. Not sure the dimensions of the intercooler, its 4inch thick, about 14 inches tall and from fog light to fog light long
