Dyno tuners suggestions-ohio
Old Jan 5, 2012 | 10:37 AM
littlereds10's Avatar
Default Dyno tuners suggestions-ohio
Wasn't sure what section to post this under, but since most forced induction guys have been to a dyno tuning facility, I thought id get the best responses from here.
Ok I'm in northeast Ohio and just about need to get a base tune and dyno tune. I've looked into Smokey's dyno in North Canton and Dynotune Motorsports in Columbus. So far, those are the two I feel most comfortable with. But recently someone told me that he knows at least 4 people who got their motor blown up by Smokey's.
I've heard nothing but good about Brian from Dynotune Motorsports but it's more of a drive for me.
I wanted to see if any of you have first hand experience with these two dyno facilities and what you would recommend.
If there are any better places that you've had good luck with near Akron Ohio, let me know
Thanks in advance
Old Jan 5, 2012 | 11:01 AM
smokinHawk's Avatar
i only know places in the columbus and dayton area
like dynotune, and ips
Old Jan 5, 2012 | 12:13 PM
So you had good luck with dynotune? I haven't heard of any misfortunes from people that go there but I just wanted to make sure
Old Jan 5, 2012 | 02:08 PM
koolrayz's Avatar
Contact Big3 in brunswick. Have Chuck hook you up with Brian he does a great job and they use a mustang dyno
Brians screenname is Sunset01TA you can PM him
Old Jan 5, 2012 | 04:09 PM
TCD's Avatar
TCD
I worked with Brian at Dynotune for 3 years. Tell him the BMW turbo guy says hi if you go.
Old Jan 5, 2012 | 06:28 PM
Ryans99ls1's Avatar
I know there is stock shortblock turbo camaro running around columbus that was tuned at dynotune. Pretty sure he's pushing 14lbs too, so the tune has to be on.
When i get mine tuned, its going to between big3 in brunswick and dynotune in columbus.. all depends where ill have the car more as id like to be close to my tuner
Old Jan 5, 2012 | 08:58 PM
Turner8396's Avatar
CRT Performance in Norwalk Ohio. 2 miles from Summit Motorsports Speedway. Great people and awesome tuners. They tuned my bolt on 99 Z28 last Spring and pulled 370rwhp 364rwtq on a Mustang chassis dyno. They also installed and tuned my 408 Supercharger engine in my 98 Trans am last fall. They are doing my Vortech Ysi intercooler and tuning next winter after I put some miles on the 408. I highly recommend them.
Old Jan 8, 2012 | 10:05 AM
LSRacing's Avatar
Someone lied to you about smokeys dyno. They are by far the best! Blown engines, yea right! Sounds like someone spreading rumors to me
Old Jan 8, 2012 | 10:08 AM
LSRacing's Avatar
Who told you that by the way?
Old Jan 8, 2012 | 02:15 PM
I'd rather not go leaking his name. But I ended up choosing Brian at dynotune. I've heard nothing but good about him. I sent my PCM to him for a base tune.
I just feel like some of the things Smokey's was telling me were just for the sales pitch and after talking to Brian, it seemed like I wont have to worry about any bs.
I'll tell him BMW turbo guy says hi when I go down there and I'll let everyone know how it goes
Old Jan 8, 2012 | 03:31 PM
Ryans99ls1's Avatar
let us know how it goes with dynotune
Old Jul 7, 2012 | 08:06 PM
nasty_ss's Avatar
what ended up happening here?
Old Jul 7, 2012 | 09:48 PM
I got a base tune from Brian at dynotune motorsports and the engine started right up. Just finishing up some stuff with the car then I will drive it down to him and have it dynoed
Old Jul 7, 2012 | 10:31 PM
simplysix's Avatar
Good choice, Brian aka. Dyno Brian is a stand up guy and awesome tuner. Ask him about the turbo hayabusa when you go
Old Jul 8, 2012 | 03:22 PM
Ryans99ls1's Avatar
brian at dyntotune did an absolutely awesome tune on my car. He's a hell of a guy
Old Jul 8, 2012 | 03:37 PM
Bobsmyuncle's Avatar
Seen plenty of garbage come out of smokeys. They got money to run a shop but no knowledge. They made some pulls on a nitrous car at a dyno day, 13:1 compression and sprayed a 125 hit at 31* of timing, and 13.5:1 afr. Was told from the guys there that that was "SAFE"
Old Jul 14, 2012 | 12:58 PM
nasty_ss's Avatar
how much boost you running? maf or sd tune?
Old Jul 14, 2012 | 04:47 PM
Ryans99ls1's Avatar
SD tune, drives awesome. i want to run 10~11lbs, but i have a manual boost controller and i cant keep enough pressure on top of the gate to hold it steady. So i turned the **** a lil more and once it fully spools it hits 12 but settles to 9lbs(which is the spring pressure) pretty quickly.
Old Jul 15, 2012 | 04:43 PM
1972nova's Avatar
Know Brian real well, hes a good guy. Tuned the nova
Old Jul 16, 2012 | 08:16 AM
BOBS99SS's Avatar
Captain Double Post
Brian tuned my car and i have been more than happy,he is a good guy
