Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
What an absolutely sick car, looked like it wanted to lift up off of the dyno and fly away. Also, judging by the little idle clip in the first video, you would never know this car is putting down 1000+rwhp, just awesome.
That wheel will support that kind of power, you just have to crank up the boost. 25 psi on a big motor like that is intense on the dyno, and on the street. I gave up at 20 psi, and made 1080 on a cast 35R wheel. Add a billet wheel, 5 more psi, solid roller, better heads, and its very much doable, all through a T3.
There is NO way a T4 is going to fit in that realestate that the APS kit has.
Efficiency is key, and these guys did a good job!
Louis
Louis
#33
**Raises Hand**
Any issues or concernes with the manifold? I'm aware the 102 is supposed to be much more structural than other composite manifolds, but I still find it to be a concern with that kind of manifold pressure. Guess you won't know for sure until race day, but I thought I'd ask!
Awesome build
Awesome build
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#34
So far no issues at all with the LSXR 102 guys....
Also, our customers 19x12 360 Forged rears showed up Friday. Time to mount some 345/30/19 Drag Radials and see what this combo can do!! So far on street tires the car is completely useless, even on pump gas...
