my 76mm Turbo LS1 Miata ***Lots of Pictures***
#43
Not sure if you have already mentioned it, but what kit did you use to get the LS in there?.....
Also on the cross over / merge of the two exhaust p[ipes into one, whats the expanded section that then reduces back downto normal pipe for?
Thanks,
Chris.
Thanks,
Chris.
#45
The expanded section is where the 2 pipes merged together (obviously lol) but the 2 pipes were at weird angles so we put it together using an oval pipe and then merged it in to a regular 2.50" circular pipe... Make sense?
Thanks for the comments guys
#46
Its a V8 Roadsters "rearwards" kit... Requires expanding the firewall..
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
How did you find the V8 roadsters kit?
Chris.
#48
Any updates?? I'm curious as to how many miles you've logged so far. Any issues with the turbo? Any thoughts on using this type of turbo in a daily driver/commuter LSX swap? I'm REALLY considering going this route, but I'm logging 2 hrs/day on the commute. Thanks for any insight you might have.
#49
Just watched your video bro...awesome to say the least. Now with the dick riding out the way...WHAT THE HELL DID THOSE CORVETTES HAVE IN THEM!!! They were pulling away while you were spraying...epic!
#50
How does it compare to the flyin' miata kit? Or am I wrong and they're the same kit? I'm researching doing an LS Miata myself. That car looks like a hell of alot of fun!
