A little Help Please Vortec G-Trim
Old Jan 9, 2012 | 08:33 PM
sean1997ws6's Avatar
Default A little Help Please Vortec G-Trim
Hey all, I am looking at buying a vortec G-Trim Kit with everything minus the harmonic balancer, Fuel pump and injectors, My question is, What size injectors does the kit come with? My car is a stock LS1 with LTs and bolt ons. How much is the kit as stated worth in your opinions? Any help would be great guys.
Thanks, Sean
Old Jan 9, 2012 | 09:59 PM
phatasp's Avatar
Intercooled or not intercooled. Make sure you can get a balancer and the other parts before you buy because Vortech discontinued the f body kits and they do not sell anything for them. Complete, the kits probably worth about $2500. There,s a complete t-trim kit in the for sale section for $3500 which would be a good way to go.
Old Jan 9, 2012 | 10:01 PM
its has the aftercooler. Thats what I was worried about, where can I find a HB?
Old Jan 9, 2012 | 10:24 PM
phatasp's Avatar
The only place I can think of would be RMCR, they,re a sponser on this website.
Old Jan 9, 2012 | 10:27 PM
Thaks man, I know they say you have to trim the hood on the Camaro, do you know if it will fit on the WS6?
Old Jan 9, 2012 | 10:31 PM
vrtch ss's Avatar
I believe ATI makes the super damper for it but you will require the vortech pulley to bolt on to it.
Old Jan 9, 2012 | 10:58 PM
phatasp's Avatar
My balancer is a ATI. A g-trim will fit a ws6 without trimming.
Old Jan 10, 2012 | 01:44 PM
The kit says it comes with 38lb injectors, that seems light to me. What size injectors are you guys using with a similar setup?
Old Jan 10, 2012 | 02:00 PM
JRENIGAR's Avatar
Im running the siemans flow matched 60's from Fuel Injection Connection on mine thats making the #'s in sig on a stock 190k mile engine, auto trans, and rearend with 3.23's.
Old Jan 10, 2012 | 06:06 PM
Thanks, What damper will I need with the G-trim? The kit I am buying does not have one with it, just the pulley. people said ATI, is there a part number?
Thanks, Sean
Old Jan 10, 2012 | 06:59 PM
JRENIGAR's Avatar
Looks like Vortech still sells the part, its # is 4GK016-011 and lists for 1,044.95 before shipping. Im not sure if its custom or not like Vortech's rep said it was but mine has a 9 bolt pattern with 6 holes for the pulley to bolt up to. The other 3 are to keep the damper assy together, I guess. Good Luck...
Old Jan 10, 2012 | 07:46 PM
ATI says that 918853 is built for ls1 with supercharger applications. Can anyone confirm this so I can be sure it would work?
Old Jan 11, 2012 | 03:25 PM
JRENIGAR, Did you install your G-Trim kit yourself? How hard was it?
Old Jan 11, 2012 | 07:32 PM
phatasp's Avatar
I did mine myself, not too hard, mostly time consuming. follow the directions in order and you,ll be fine.
Old Jan 11, 2012 | 07:42 PM
JRENIGAR's Avatar
If you did all the other mods yourself, then this should be doable as well. I would give it a weekend just to be sure, and have a lil help just incase.
Old Jan 11, 2012 | 08:08 PM
Yea, I did everything myself and have assembled a few engines. I downloaded the instructions off vortech and it didn't seem to bad. The after cooler looks to be the pita. The car is a garage queen so I can take my time.
