Does anyone make a belt that has a "grip surface" on the smooth side of the belt?
Old Jan 10, 2012 | 09:31 AM
dville_gt's Avatar
Default Does anyone make a belt that has a "grip surface" on the smooth side of the belt?
The way my belt routing is I have very little contact with the waterpump pulley. This has never given me issue, but I'd like to be more pro-active about it. Does anyone make a 6 rib belt that has some type of "grip" surface on the smooth side that contacts the water pump?
Old Jan 10, 2012 | 09:36 AM
Awake455's Avatar
Unless it's spinning a clutch fan the water pump doesn't eat too much power. I've set up some custom serp drives without much wrap on the water pump and all was fine. Doesn't Mezerie make an electric for the lsx engines with a pulley mounted on it or do I need to put the crack pipe down?
Old Jan 10, 2012 | 11:50 AM
tripblackls1's Avatar
Yes they do but there also like 600+ $$ , which is outrageous if you ask me
Old Jan 10, 2012 | 12:49 PM
BadgeZ28's Avatar
There are few applications that came with grooved on both side belts. I think it was a two year run of the C4 Corvette that uses them. Another option could be the carbonite coating of the pulley surface.
Old Jan 10, 2012 | 06:06 PM
stevieturbo's Avatar
Might be easier to add another idler.
How bad is the contact ?
