heads use for a 5.3
Old Jan 17, 2012 | 11:31 PM
i wanna go fast's Avatar
Default heads use for a 5.3
new here and this is my first post. i have a 5.3 im building and doing the usual ls6 cam(01) and other little things. but i have a set of ls1 heads sitting around and wondering if i should put those on? my theory is it will drop the compression which is better for boost. the combustion chamber volume for ls1 heads is 66.67 while the 5.3 head is 61.15, so that would allow for more boost as well plus the intake valve is bigger on the ls1 head, so does this sound like a good reason to try it out or just stick with the stock heads knowing they are already proven good for boost?
Old Jan 18, 2012 | 02:04 AM
Packy's Avatar
I'm using stock 241's on my 5.3 build for a s/c'ed setup.
Old Jan 19, 2012 | 08:21 PM
do u know what ur compression is? how much boost?
Old Jan 19, 2012 | 08:41 PM
mpatton's Avatar
Curious also im between 243s or 241
Old Jan 19, 2012 | 10:15 PM
WS6HUMMER's Avatar
Can you put 317's on a 5.3? Wanna cheap aluminum block & thought it might be worth stroking a 5.3 but never thought about if 317's would fit. Just kicking around ideas.
Old Jan 20, 2012 | 04:55 PM
Packy's Avatar
You can use 317's on the 5.3's but it does drop the comp. ratio down a lot. Some guys have done it and complained about the car being very sluggish out of boost. I am thinking it will be about 9.5:1 comp. ratio with some 241's, LS9 gasket and an aluminum block 5.3. I have yet to assemble it. I am waiting to get a cam and some new lifters first.
Old Jan 20, 2012 | 06:19 PM
Super6 N GA's Avatar
Default doggy
i hear a lot of this over here on how the car feels doggy out of boost. i come from the Buick world and i would say i am use to a car being real soft out of boost. one thing i done with my buick was run a thinner head gasket to bump the compression up a half point. the car felt much better out of boost but with 6 holes it wasn't much of a jump in power. i have a 5.3 i am going to use 317's on..going to try and get the compression around 9 to 1 by milling the heads..bought a 5.3 turned out to be 4.8..bought a rotating 5.3 assembly now to make it a 5.3 wish i could use the 4.8 flat tops on the 5.3 rods but the 5.3 rods are suppose to be floating..not sure if the 05 4.8 i have has floating rods....hth somebody Bob
Old Jan 20, 2012 | 06:25 PM
WS6HUMMER's Avatar
If I went the 5.3L route I would like to use 317's, I would hope to take up the slack in the compression with aftermarket pistons. I guess that would work.?
Old Jan 21, 2012 | 09:11 AM
bmech211's Avatar
The 317's will drop CR by about a point, but there are a few 5.3 motors with varying CR's. Some Gen IV's with flex fuel and active management have 9.9:1 and flat top pistons, which could be confused with the 4.8's.
Old Jan 21, 2012 | 07:53 PM
rpturbo's Avatar
On a budget, I have heard some guys run 4.8 flat tops in the 5.3's to bring up the cr, not sure what it would make the cr with 317's though. Anyone?
Old Jan 21, 2012 | 09:02 PM
slow67's Avatar
Gingervitis Addict
9.2 to 9.3
Old Jan 21, 2012 | 10:09 PM
Fbodyjunkie06's Avatar
Originally Posted by slow67
9.2 to 9.3
Listen to this guy.
Old Jan 21, 2012 | 10:36 PM
cjvmboricua08's Avatar
i'm running 317 with flats and pulling 9:1:1 on my 5.3
Old Jan 22, 2012 | 12:59 PM
slow67's Avatar
Gingervitis Addict
It can move around a little depending on what your deck height is and your head gasket.
Old Jan 23, 2012 | 12:20 AM
socal's Avatar
317's here
Old Jan 23, 2012 | 06:51 AM
Fb0dy0nly's Avatar
Originally Posted by socal
317's here
on a 5.3?
what compression?
how does it feel down low?
what gaskets?
Old Jan 24, 2012 | 11:33 PM
so what is the ideal compression for boost?
