limits of aster bracket?
Old Jan 24, 2012 | 04:48 PM
CyaPussy's Avatar
Default limits of aster bracket?
I know alot of guys are running these now curious if anyone has had issues with it once they reached a high hp level.
Old Jan 24, 2012 | 09:15 PM
blue00ZZleeper's Avatar
How high are you talking about? Theres guys putting down pretty good numbers with it so far.
Old Jan 26, 2012 | 07:33 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Hopefully some people will chime in on this, as I am curious too. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 26, 2012 | 08:50 PM
SUPERMAN_00TA's Avatar
Ill get back with you soon..... Dyno next week hopefully
Old Jan 26, 2012 | 08:55 PM
I'm right around 830rwhp so far with no issues....plan on going further soon
Old Jan 26, 2012 | 09:06 PM
jjcamaro02's Avatar
I am maxing out my D1sc with the Aster bracket. Not sure exact power some were around
700 rwhp. Times are in my sig. Very happy with this setup. This is with a 3.4 pulley.
Old Jan 26, 2012 | 09:13 PM
Your just out of blower now....Great times and Trap speed....how much does she weigh? lol
Old Jan 26, 2012 | 09:16 PM
jjcamaro02's Avatar
Yes out of blower will be upgrading soon i hope. With me in the car weighs about 3750.
Old Jan 26, 2012 | 09:41 PM
vicouSS00's Avatar
I've about made my mind up that my first mod in 2012 will be the Aster bracket. The most boost I've been able to see with the stock procharger bracket was 12.5 and it's slipping the whole time. If I pullied down as much as I could what do you guys think the max boost I could see with my 408/F1A setup using Aster's bracket? I know there are several factors as to that but I was just thinking ballpark numbers. Car has an ls6 intake and stock 317's..
Old Jan 27, 2012 | 08:40 AM
You should probably be seeing 15+ psi if its pullied all the way down. I see 18psi with my standard F1, Stg 3 LS6 heads and a LS6 manifold. On your larger CI you'd see a little less boost pressure but with the F1A you should see a little more CFM. What did she put down on 12.5psi? With my 370 on 13.7psi she made 706/641, 15psi was 780/760 and on 18 it was 826/726 (Clutch was done for)
Old Jan 27, 2012 | 08:52 AM
LS1Tech Sponsor
With my old '99 Z28 we were running the stock J bracket with an F-1A on my 408, we were seeing 18 to 20 psi with the 7.65 crank pulley and a 3.90 blower pulley. We had terrible problems with belt slippage, had to tighten the belt after every run.
KP was running the SDCE bracket and with his F-1A he never had to even look at the blower belt. From what I have seen the Aster bracket gives the same "keep the hood shut" results. It will be interesting to see with the F-1R blowers if belt slip is a problem. Bob
__________________
Old Jan 27, 2012 | 08:59 AM
I'll let you know Bob lol
Old Jan 27, 2012 | 01:44 PM
speedracer5532's Avatar
I had Aster's bracket with a F1R head unit making around 940 rwhp and had nothing but belt problems. I kept breaking the 8 rib belt but I don't think that was a problem with Aster's bracket. I broke belts with the SDCE setup also. I feel I was exceeding the capability of the 8 rib belt. I never had belt problems when I had a F1A head unit. I finally went to a cog setup and no more belt problems.
Old Jan 27, 2012 | 09:25 PM
Speedracer....you and I need to talk lol. I plan on keeping my 6spd and need some advice on my setup lol
Old Jan 27, 2012 | 09:42 PM
Fb0dy0nly's Avatar
To keep the 8 rib or run the cog setup....decisions decisions....
Seems like problems are arising around the 8-900whp area for some/most in this thread. Wonder if anyone is hitting over the 1k mark with minimal slippage and no breaks on the aster?
Old Jan 28, 2012 | 07:54 AM
Sounds good
Old Jan 28, 2012 | 08:55 AM
Inspector12's Avatar
TT-TECH Veteran
Well I am like Speedracer, but I didn't have as much belt issues as him etc... I made 1035rwhp with the F1R. There still seems to be some slip at times, but for the most part it holds ok. I did go through a few belts at first, but after making some adjustments I didn't have an more issues. Overall review is as follows lol! I don't feel like it holds any more power than say the SDCE bracket setup I was running, but it is a lot better designed and the belt doesn't move around as much I am guessing because of the contact with more pullies etc... The belts still get worn and have to be replaced to keep the car at peak performance and ofcourse I'm talking about when pushing it with a large head unit such as an F1C or R. I am guessing because of the afore mentioned slip that still occurs sometimes when cold etc... The longest I ran the same belt was about 8months and I still have it and it looks ok, but you can tell its worn. And when I swapped to a new belt, it was a whole other animal again lol! I believe that it needed just a tad stronger tentioner and it would have probably fixed the minor slip that happens at cold times mainly etc... Aster(Chris) is a very cool guy and did an excellent job with the design of his bracket and customer service was second to none! Hope this helps some of you guys.
Old Jan 28, 2012 | 10:46 AM
SilverSS's Avatar
I'm one of the very first people to get Asters brackets well before he started getting theses things out officially. It has maxed out my F1A with no problems and has been 100% reliable for me other than the normal worn belts.
Old Jan 28, 2012 | 01:38 PM
What belt is everyone running? I was running the NAPA HD belt (green belt) and I would pull the belt into.
Old Jan 28, 2012 | 02:55 PM
madball's Avatar
What cog kit are you running with the manual? I am in the process of building my 6 speed TA and have a used EPP cog kit and ATI sprag pulley and was curious as to what you are running.
