does mount orientation of a wastegate matter?
Old Jan 26, 2012 | 06:46 PM
Ryanbgb22's Avatar
Default does mount orientation of a wastegate matter?
I have a front mount truck manifold setup. I plan on running 2" piping from where it comes together under the turbo flange to the wastegate. Does it matter how the wastegate is mounted - sideways, upside down, straight up and down? Due to space constraints, it would be easiest to mount it sideways, if that makes sense.
Old Jan 26, 2012 | 07:59 PM
tripblackls1's Avatar
does not matter how its positioned (up, down, sideways) as long as you have good wastegate priority
Old Jan 26, 2012 | 08:02 PM
make sure you are getting priority from both sides of the crossover as well, for example if you have your two pipes coming to a merge, then you want it in the middle of those two pipes, not off to oneside or the other
Old Jan 26, 2012 | 08:27 PM
Build-it-Break-it's Avatar
This might help.
Attached Thumbnails does mount orientation of a wastegate matter?-precisionmanual.jpg   does mount orientation of a wastegate matter?-5529.jpg   does mount orientation of a wastegate matter?-downloadedfile.jpeg
