Turbo Firehawk build up V 3.0 AES 385 and S88
#63
Well progress has slowed some due to me going to traning for 2 days last week and taking 3 large trees down at my house but I have made some more progress.
I built my merge for the waste gate. I was just waiting on the correct flange to show up for the waste gate(it showed up today)
I also rebuilt my turbo support in a round bar instead of the square tube. And I started welding nuts into the frame to mount the turbo support bar. I only got one side done before running out of wire in my mig
Some other misc pics
Also picked up some AN wrenchs
#64
Made some more progress today. I got the merge/waste gate pipe all welded up. Also got the mounts for the turbo support finished up.
A look from inside the pipe that to what feeds the waste gate
A couple pics of the turbo support
Turbo and rad in just for checking clearances
#71
A little more progress. I got the cross over all moched up and taced together. It is turning out nicely.
Also my Carbon fiber sheets showed up today that I plan to use 1 to fill in the area from the radio/ HVAC pannel where I will be mounting my 2 step controller and some other items. The other will likely be used to make a fuse and relay mount under the dash so I can better wire all my gauges and other extras
#74
This is going to be one bad *** car!!!!!!!!! I'm doing the same thing using my twin scroll 1.32. S480. Any reason why not two gates? i am deciding on running two or one big one. Thanks to Martin (fbodyjunkie) he has steered me in the right direction!
#75
Trying to make some things look nice and not like I butchered the car
http://www.sierracomposites.com/category-s/22.htm
Thanks I really like how it has turned out so far
I already had the JGS 50 mm waste gate from my previous build so it got reused. If I didn't already have it I would have likely done twin waste gates
This is Awesome great work! This is going to be one bad *** car!!!!!!!!! I'm doing the same thing using my twin scroll 1.32. S480. Any reason why not two gates? i am deciding on running two or one big one. Thanks to Martin (fbodyjunkie) he has steered me in the right direction!
#77
Progress was slow the end of the week and over the weekend as I bought a new shed and had that delivered Friday. I did get the cross over done and welded up. I also put my wastegate back together with new seals and spring that should get me 8-9psi on the wastegate instead of the 15 I had before. Should make things a little friendllier on the street. I need to make a trip down to local place and pick up some 4" mandrel bends to finish off my down pipe. Here are a few pic
#78
Well cross over is complete and down pipe is all tacked into place. Just need to finish weld down pipe, build my lower rad mount(need some mounting points welled onto the rad), lay out the cold side pipes and work on making some sort of intake/filter set up for the turbo. Once all that is done I will be pulling the motor and trans again to clean up and repaint the engine bay. Also going to work on cleaning up the wiring more
#80
Thanks. It is coming along. I got thr rad mounted today. Made my upper and lower mounts for the rad. My lap top is broken so I can't post any pics right now. I will get some up in thr next couple days. My biggest issue right now is work has slowed down for me big time so my money to buy parts for the car is gone. I still need to buy a torque converter and some other small odds and ends
