Turbo Size
Old Feb 4, 2012 | 07:44 PM
Camaro9969's Avatar
Sounds like the S480 S482 would be a good fit for a stock 6.0 and even better for when its built. The 482 i found for about 1500 I like the borg turbos because they really perform well ive seen some monster numbers out of them
Old Feb 4, 2012 | 10:42 PM
tiznodd's Avatar
Is this a race only deal, or do you plan to drive it on the street? Auto or 6 speed?
Old Feb 5, 2012 | 07:46 AM
Camaro9969's Avatar
Its an 6 speed now but switching it to a Auto for the turbo. I'll drive it on the street and be at the track hopefully every weekend.
Old Feb 5, 2012 | 03:33 PM
Camaro9969's Avatar
Also am going to run E85 fuel and want to get a cam for it
Old Feb 5, 2012 | 05:46 PM
Nitroused383's Avatar
To clear some things up when comparing turbine wheels, some companies give specs for the inducer and others spec the exducer. Precision gives specs for the exducer (smaller end) and Borg Warner specs the inducer (bigger). 7675 turbine = 75mm exducer 83mm inducer. Make sure you're comparing apples to apples when looking around. 7675 is basically the same thing as a s475 with a T4 83mm turbine except being much more compact and having a more efficient comp wheel.
Old Feb 5, 2012 | 06:32 PM
Fbodyjunkie06's Avatar
This is true, and Borg does mainly spec theirs with the inducer size.
I still think the Borg S482 T6 96mm turbine side 1.32 ar will work wonderfully even on a built 6.0. I'd say the Borg S480 T4 87mm or 92mm turbine 1.10 ar will work great on a stock 6.0 and still be good for at least 900rwhp especially on E85.
There is a guy on the boards from KY that just had Bluecat tune his car on E85. he has a S480 or S482 on E85 and on 17-18psi (IIRC) it made over 850rwhp on a stock bottom end 6.0.
Work turbo's is having a sale on most their borg stuff right now and IIRC the S480 96/88 turbine 1.32 ar is 1075 and the S482 96/88 1.32 ar is 1500 like you said.
Old Feb 5, 2012 | 08:17 PM
dean85gt's Avatar
You guys think an s400 with t6 and 1.1 AR is too big for a stock 5.3? Forced inductions has some good prices on those too...
Old Feb 5, 2012 | 11:44 PM
Texhotrod593's Avatar
Depends on what power you want to make... Try S400SX-75 1.10 83mm T4
It wont choke or run out of steam>>>>and look at that price! It might be a tad laggy depending on your setup but will give some room to grow
Old Feb 6, 2012 | 07:20 AM
Camaro9969's Avatar
So either would work it sounds like. maybe the 480 would be better to start with thats a 88mm turbo alll these numbers are confusing........So whats the difference between the S480 and a S88? I'm def going Borg i see awesome numbers all over the place
Old Feb 6, 2012 | 07:43 AM
ZL1Killa's Avatar
Originally Posted by Camaro9969
Wow thats nice. What kind of boost and fuel? i was thinking of doing E85
14psi and 93 octane on the old 5.7L motor, don't know what it will make on this new 6.0L but I imagine at least 50 more hp and tq throughout the rpm range. only thing with E85 is larger injectors & fuel supply
Old Feb 6, 2012 | 08:49 PM
If I am not mistaken.... 8mm difference.
Old Feb 7, 2012 | 04:23 PM
  #32
Camaro9969's Avatar
Bigger or smaller? I might be opening up a can of worms here but what fuel system will i need i? the hp is listed above id like to be around 700hp now and around 900 next motor. I saw some 60lb injectors on here would those be good?
Old Feb 7, 2012 | 05:45 PM
  #33
Orr89rocz's Avatar
On E85 you may want to look at much larger stuff, 116-120lb injectors for the next motor. Not sure but dual walbros may be enough. I've seen over 800 on E85 with dual pumps on a stingy mustang dyno.
Old Feb 7, 2012 | 07:31 PM
  #34
Camaro9969's Avatar
Wow those are some monster injectors!!!
Old Feb 7, 2012 | 08:30 PM
  #35
I am probably not the guy to talk about the borg turbos....hopefully Dr. Turbo will step in! I am thinking it goes like this(even though i will prob be corrected), With the Borg turbos you have series numbers. I bet its for the frame size. Lets say a s400sx-80 is the same frame or "series" as a s400sx-75. The only difference is the size hence the 80mm and a 75mm. Since it is a 400 series turbo you can call it a s480 or a s475. They have a ton others too...s482(im guessing a 82mm) s476 etc. They also have the 500 and a 300 series. Like I said, I think thats the frame size. Someone can correct me if I am wrong please
Old Feb 7, 2012 | 08:34 PM
  #36
Yeah but you have to flow a ton of fuel for E85 and 900whp...I would think he is right. Triple walbros and prob somewhere from 10x-12xlb injectors
Old Feb 10, 2012 | 03:35 PM
  #37
Camaro9969's Avatar
Well just ordered my turbo went with the S480 and the Race cover Should be a monster.....I hope anyways wasnt as expensive as i thought either.
Old Feb 10, 2012 | 09:03 PM
  #38
You are 100% correct. The 300, 400, 500 designates the "chassis" of the turbo.
I think you will be very happy with the turbo you chose.
If you want E85 and you don't want to do things twice get at least 120lb. injectors now, and run a triple walboro 255 pump set-up like mighty mouse did on his car. Now MM run's 96lb. injectors and gasoline instead of corn, but it is good for over 1300rwhp in his car, roughly 33% of that is 875-900rwhp. With the 120's over the 96's you should be able to make 100rwhp more, as his 96's are maxed completely out right now at 1300rwhp.
Old Feb 12, 2012 | 03:55 PM
  #39
Camaro9969's Avatar
thanks for the advice i was thinking 120's would do well and thats why i picked that turbo because i dont want to do this build twice might as well get everything now so the potential is there
Old Feb 13, 2012 | 06:33 PM
  #40
Camaro9969's Avatar
Now its transmission shopping time.....th400 probably ..
