Should I build a 346, 370 or 408
Old Feb 7, 2012 | 11:50 PM
4kiro's Avatar
Default Should I build a 346, 370 or 408
Ok I currently have a stock ls1 with a f1a. I want to build it up to about 800hp. I was planning on running meth, 91 and Bob's blower cam and stock 317. Should I even bother with that and just start building a new forged motor? What motor should I start to build? The car is a weekend car, I want it for show but I want it to go. Currently it has a M6 but I suck at driving it that I might have to get an auto. Plan on going to the track about three times a year. Any advice is welcomed.
Old Feb 8, 2012 | 12:34 AM
badazz99ss's Avatar
Id say a 370
Old Feb 8, 2012 | 01:05 AM
6ltr's Avatar
Stock stroke for the piece of mind and longevity
Old Feb 8, 2012 | 01:10 PM
Texhotrod593's Avatar
Originally Posted by 6ltr
370
Bingo...I concur
Old Feb 8, 2012 | 02:09 PM
4kiro's Avatar
Well good that was easy, You guys think I could build one cheaper than buying one from someone like TSP.
Old Feb 8, 2012 | 04:29 PM
N2OBaby's Avatar
How about a 390 from AES?
Old Feb 8, 2012 | 04:44 PM
jt76's Avatar
I have about $3200 into my 370 incl
-6.0 iron block
-compstar rods
-mahle pistons + rings
-ARP main and head studs
-ACL coated bearings
-Machine work
-Stock crank polished
Old Feb 8, 2012 | 06:31 PM
MRMonster's Avatar
Excuse my newbness to bored and stroked motors but a 370 is just a bored out 364 right? You can't make a 370 out of a 346?
Old Feb 8, 2012 | 07:06 PM
You are pretty much right. Only way to may a 370 or larger is to re-sleeve it. In fact i have seen at least one build on here that i believe its a 427 re-sleeved ls6 block.
Old Feb 9, 2012 | 12:18 PM
blue00ZZleeper's Avatar
On the stock LS1 motors, you can get up to a 396ci but its not good for FI. The max bore you can take a LS1 out to is a 3.905". There's 3.8", 4.000" and 4.125" stroker cranks you can use but none of them are advised for FI builds....some venture there but they are bold! lol Most 370ci motors come from either LQ4/9 iron motors or a LS2. I've put down 830rwhp on 18psi with my 370/Old F1 combo so far. IMO a 370 is one of the best bang for the buck FI motors you can do. With a 4.030" bore it will help to decrease valve shrouding, increasing flow and it will be very reliable.
Old Feb 10, 2012 | 12:00 AM
4kiro's Avatar
Thanks ZZ, knew I could count on you for good advice.
Old Feb 10, 2012 | 07:17 AM
oops...My bad. I was thinking the biggest on stock stroke. Actually I have a 3.905 bore myself and you can go as big as 3.908 which will make a 348c.i. with a stock 3.622 stroke and a 383 with a 4.00 stroke. A 3.905 bore with a 4.00 stroke will actually be in the 382 c.i. area FWIW
Old Feb 10, 2012 | 09:13 PM
I don't think anyone takes a LS1 out further then a 3.905" really. It removes to much from the cyl walls leaving them thin and weak, also able to distort easier. Remember with boost, your adding a lot more cyl pressure. With that bore you can use a 3.800", 4.000" (383-ish) or a 4.125" (396-ish) but none of those strokes are really advised. I've been looking alot into oversquare motor (bigger bore then stroke) and that seems to be the best route. Like I said a few guys have done it but myself and others steer away from greatly stroked FI motors....to many issues to arrise.
Old Feb 11, 2012 | 11:21 PM
Slo_240sx's Avatar
I was on my way to building a 402 or 408 but I've steered away from the 4" stroke as well. Plus, stock cranks have been pushed passed 1000+hp which helps the cost of buying forged ones. Now I'm just waiting for my boy blue to come back from Afghan so I can buy his motor!
Old Feb 12, 2012 | 08:23 AM
I8UR4RD's Avatar
so I am in the process of building mine as well, and this was a question on my mind. So keeping the stock block at 347 with the 3.905 bore will indeed keep my cylinder walls thick and allow me more reliability at 700+rwhp? I will be achieving this with a set of 225-227 heads with a 3/4 deck, diamonds, callies, and katech rod bolts, and studs. this will be a d1 car. not and f1.
Old Feb 12, 2012 | 09:10 AM
You'll be fine with that setup. You'll easily make into the 700's on 17psi or so I'd think.
Old Feb 12, 2012 | 09:36 AM
Slowhawk's Avatar
LS1Tech Sponsor
For a street car I always point towards bigger cubes like 402/408. More average power and longevity is not an issue.
Old Feb 12, 2012 | 06:57 PM
Blownz28man's Avatar
For the Hell of it I built a Iron 347. The 5.3 block I have nothing into. Has Weisco pistons/compstar rods. Looking for 700hp tops.
Old Feb 12, 2012 | 07:17 PM
98BLOWNZ28's Avatar
Do you have the f1a on the ls1 now?
If so, what kind of power are you making?
Old Feb 13, 2012 | 09:56 AM
4kiro's Avatar
Made 5.08 at 6300 with 471 torque. On a dynojet. No tracks times yet.
