5.3 Turbo First Start - Valvetrain Noise
Finally started the Camaro for the first time tonight. Its a 5.3 longblock, 224/228@114 cam, precision 76.
It ran for about 30-45 seconds before I shut it down. Oil pressure was 50+ psi, but it seemed to have an unusual amount of valvetrain noise. I replaced the valvesprings with PRC dual springs, hardened pushrods and new valve stem seals along with the cam. The longblock was purchased from a local salvage yard. The heads have never been off, so the lifters are original.
Whats the best way to begin chasing down a noisy valve train or oiling issue? Any other thoughts or experiences that relate?
Thanks all
Thanks all
Just run it till its hot,and the lifters should pump up, as long as you have good oil pressure.
Did you check lifter preload after fitting the cam to determine the correct length pushrods ?
JohnV, yes and I ended up going with a 7.425" rod. So the engine will need to reach operating temp or close for the lifters to pump up the first time?
Thanks all for the input. Once I purchase hp tuners, I plan on modifying the injector tables for the 60lb siemens that are in there and letting it warm up to operating temp.
Any other initial modifications suggested? Im new to tuning. I purchased Greg Banish tuning dvd and injector table dvd last week. Ive been poking around the hptuners board for some time, but definitely need to spend a lot more time on there.
Lifter preload should remain as it was stock. The base circle on the cam was .050 smaller in diameter, so .025 shorter radius. I went with 7.425 pushrods to compensate. The rockers are stock, not adjustable. Whats the best method to measuring lifter preload?
