Show me your FMIC
And if you went f1, you might wanna have some extra cash laying around to build your motor if something happens. And a fmic will def. Help you out. And you can run an intercooler without cutting anything out. Just take your time with placement and such. But I do know an f1 will require some cutting of the rear of the radiator support to fit a proper sized intake on that thing. It's easy to choke it.
https://ls1tech.com/forums/appearanc...tom-cover.html
im just curious if a FMIC coulld even fit with out lossing the fogs.
so i was looking at pictures and i was just wondering if there was any way to mount the fogs to the underneither of the intercooler and just have them pushed futher out towards the front of the car?
Hard answer...... https://ls1tech.com/forums/forced-in...rontmount.html
Keep doing research on here. There is MORE than enough info floating around. Don't expect people to just 'spill the beans' all the time. They were in your position at some point and spent a lot of time researching. Good luck!
im thinking of procharging my 99 WS6. need some ideas of how this is gonna work.
I didnt wanna go FMIC because i wanna keep the front plate and the foglights
IS THERE ANYWAY PAST THIS!?!?!?!?!?
also what meth kit did you use? what injectors? What spark plugs? what fuel pump? etc. etc. and why?
and any suggestions?
Link>>>>http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm
Thanks Bob if you read this!
Obviously this is my SS, weather this works on a T/A I can't tell ya'. I would assume so. My Formula and Firehawk are N/A cars.......
This should be able to work for your "cutting the front bumper part", as far as keeping the fogs......
still have a few ???s
THE Supercharger: D1SC from Brutespeed
Aster Bracket In Place Of Standard Bracket?
Substitute Truck Inlet and Larger Air Filter?
Mass air or speed density?
Fuel Pump: twin in-tank walbro system
INJECTORS: 60LB large enough
TIMING CHAIN: (like LS2) or a dual timing chain?
OIL PUMP: possibly ported one?
GAUGE POD:got one
BOOST GAUGE:Glowshift
WIDEBAND O2 SENSOR: Glowshift
METHANOL INJECTION: Snow Performance or Alkycontrol
got full exhaust to help flow, have a monster 3 clutch, ill have a rear and built suspesion,
it will be tuned at a safe range for a stock ls1. then ill build a 408 and the tranny up when they need it
so does this kit have everything but the procharger itself?
and i suppose that race valve is a blow off valve?
If any of u were wonderin the specs: 403" alum. Ls2 , made 660 on 14# made 870 on 18#. Goin back to the dyno on 22# to try and break the ysi record
Btw, hope I don't come across sounding like I'm on your *** or something. I'm also 19
Thats why im asking questions on here. Ive done research and it still erouses questions. So isnt this the reason of a form? To ask questions and gain knowledge?
And there are plenty of teenagers running FI cars and money isnt the issue.
Ill have a 9" rear and the stock t56 can handle up to some 550wrhp i read once. Not to mention many people run alot of rwhp thru a stock t56 and ive ran into many of stock ls1s on 8lbs of boost. Ticking bomb? Yes no maybe so. With the right tune, it can and has been done.
I appriciate you comment mostly because you were an ******* like some of the people ive ran into on these threads. I appriciate your thoughts and thanks for answering a few questions for me.
Nice fab work but it looks like i wouldnt be able to keep a stock hood with that.
