3" down pipe with stock k-member and mounts?
Old Feb 15, 2012 | 09:38 PM
Ryanbgb22's Avatar
Default 3" down pipe with stock k-member and mounts?
I have a stock k-member and stock mounts. I'm looking to run my 3" down pipe to a conventional exhaust - want to avoid running a dump or out the fender. Am I better off on the driver side or passenger side - Driver side is real tight with power steering, and the passenger side has the starter and the oil level sensor. Does anyone have any pictures of this done?
Old Feb 16, 2012 | 06:22 AM
pwrtrip75's Avatar
Passenger side I did... My old setup I ran 3.5" pipe, notched the motor mount stand a little. There is tons of room there.
Old Feb 16, 2012 | 07:39 AM
Ping King's Avatar
Are you planning on keep the AC? Tell us more about your plans. I was able to squeeze a 3" downpipe on the drivers side with a truck manifold, but i built a custom motor mount and pedestal.
Old Feb 16, 2012 | 09:50 AM
boss79z's Avatar
I have solid motor mounts and 3 inch do. Stock k member
Old Feb 16, 2012 | 12:27 PM
pwrtrip75's Avatar
heres my 3.5" It was tight, you had to know the combonation to get the pipe in there...lol.. Twist and turn it a certain way.
Old Feb 16, 2012 | 01:35 PM
Doobie52's Avatar
If Modular Turbo or CRB Performance sells the drivers side motor mount that comes with their $799 kit separately, you should check it out. Using the stock k-member with that motor mount, there's a ton of room on the passenger side. Definitely enough to run a 3.5" down pipe through there.
Old Feb 16, 2012 | 06:17 PM
Ryanbgb22's Avatar
Great, thanks. Did you reroute the starter wiring? Any worry / issue with heat on the starter / oil pan / oil level sensor?
Old Feb 17, 2012 | 09:17 AM
pwrtrip75's Avatar
No, its just zip tied up to the starter. The pipe turns down once it goes through the k-member and around the starter. Then is bumped up to 4"
