E85 plugs for 15psi boost
Old Feb 17, 2012 | 06:48 AM
maxgee's Avatar
Default E85 plugs for 15psi boost
Been researching and appears 20+lbs boost that 7 and up are better/safer plug to go with. Haven't seen much of what guys are running that are at 15lbs.
For those running 15psi give or take a pound, i'd like to know your observations on the plugs you are using, ie timing, boost amount, CR, fouling, etc...and anything you feel is pertinent.
Thanks in advance.
Old Feb 17, 2012 | 07:45 AM
AutomagicLS1's Avatar
i'd still run the br7ef's
Old Feb 17, 2012 | 10:02 AM
maxgee's Avatar
What gap are you running?
Old Feb 17, 2012 | 01:33 PM
gsxr1k2's Avatar
+1 on that. I have had no complaints running those @.025"
Old Feb 17, 2012 | 02:57 PM
run them out of the box. will be fine
Old Feb 17, 2012 | 04:09 PM
Zombie's Avatar
15psi E85 in Las Vegas heat I run TR6's, on 91 or 100 oct, TR7's. .024 gap.
Old Feb 18, 2012 | 05:31 AM
maxgee's Avatar
Got some last night and gapped them at .029
Running 13.7psi seems to run smoother under part throttle conditions.
Old Feb 18, 2012 | 08:22 AM
camaro383's Avatar
the only problem is the br7's will foul very easily when running e85 atleast, i had a fresh set in a twin turbo transam and a couple of rough starts dialing it in with some rich idleing and some rich wot pulls and they were toast, car ran a little crappy and would get a little spark blow out under wot..
so just an fyi, you might wanna put a fresh set in once you get your idle and cruising afr dialed in
Old Feb 18, 2012 | 08:39 AM
I run 9's in my car and had 10's in at one point they idled just fine on e85 with 160lb injectors
