LQ4 S480 Build
Regardless, that is going to be one nasty setup man. I bet you can't wait to drive it!
Doug
Motor is pretty basic tu2 cam ls6 intake ls9 gaskets lunati springs pushrods arp rod bolts race bearings slp double timing chain and slp oil pump the turbo is the s480 with a batmowheel race cover 1.32 96
. Good luck with your build I bet you will be running some serious fast times with your set up! The Best V8 Stories One Small Block at Time
