LQ4 S480 Build
Old May 27, 2012 | 07:59 PM
  #61
fastsspr's Avatar
Subcribed very nice project hope to see it running soon !
Old May 27, 2012 | 08:18 PM
  #62
Fbodyjunkie06's Avatar
Can't wait to see it run buddy.
It will be worth it for sure.
Old May 28, 2012 | 08:37 AM
  #63
Camaro9969's Avatar
Thanks man I appreciate all your help. I'm going to call fti about the converter Tuesday. Its shocking how fast these stupid Fittings and small stuff adds up you tend to overlook that stuff beforehand lol
Old May 28, 2012 | 11:43 AM
  #64
Fuel fittings are crazy expensive in bulk!
I am lucky to have a buddy that has 4-5 plastic tubs the size of 30 gallon rubbermaids slap full of -8 all the way to -20 fittings that I can vandalize for a small surcharge whenever I feel like it
Old May 28, 2012 | 03:55 PM
  #65
Camaro9969's Avatar
Wow lucky is one way to describe that lol
Old May 28, 2012 | 07:37 PM
  #66
Slowhawk's Avatar
LS1Tech Sponsor
I would suggest changing your fuel regulator setup. Feed the rails first and have the return off the rail go to the regulator. that way the fuel has to go through the rails first.
Old May 28, 2012 | 08:00 PM
  #67
kainedogg's Avatar
Hey Junkie, not sure if you know or not, but with the th350\400 was an adapter needed? I have a long crank LQ4 I am sticking in a C10 and wondered what other parts were needed to make them play nice.
Old May 28, 2012 | 08:36 PM
  #68
Mine has a JW LS bellhousing that mates the two right together so no adapter is needed.
Old May 29, 2012 | 06:57 AM
  #69
forcd ind's Avatar
great job-do you know what filler was used welding the steel V bands to the cast manifolds? welding steel to cast is hairy sometimes, but i wanted to do that to my manifolds so it would clear my steering
Old May 29, 2012 | 10:04 AM
  #70
Camaro9969's Avatar
I will change it up I see how it should be done
Old May 29, 2012 | 10:07 AM
  #71
Camaro9969's Avatar
309L clean the hell out of them , pre heat to dull DULL red . He said they weren't too bad to do
Old Jun 14, 2012 | 02:36 PM
  #72
Camaro9969's Avatar
Can you run speed density and still maintain use of a narrowband o2 for cruising/off boost driving? Or is it when you convert to SD its just locked in open loop?
Old Jul 20, 2012 | 07:57 AM
  #73
Camaro9969's Avatar
A few pictures with the update. All fuel lines ran 8an feed 6an return twin 255's in tank maganfuel reg. Installed the quarter stick (i hate it so if someone wants to trade a shifter let me know) Got the Moser 12 bolt with Wolfe Anti roll bar Th400 and strange chromoly driveshaft from another member on here. Got the rear end in myself a couple weeks ago just waiting for parts and it will be on the ground in about a week.
Old Aug 5, 2012 | 09:03 PM
  #74
Camaro9969's Avatar
Car is getting very close just the turbo kit left so about another couple weekends before its driving again. Got the rear in, chromoly driveshaft, Spohn torque arm. All new rear suspension, TH400 rmvb by transmission specalities, FTI Converter and Yank Flexplate.
Old Aug 7, 2012 | 01:58 PM
  #75
Reject's Avatar
Very nice man
Old Aug 7, 2012 | 02:49 PM
  #76
N2OBaby's Avatar
Nice Camaro there.
Old Aug 7, 2012 | 03:27 PM
  #77
MUSTANGBRKR02's Avatar
Better hurry up so you can drive it before it snows!!
Old Aug 7, 2012 | 08:14 PM
  #78
Camaro9969's Avatar
Haha a few weeks and ill be driving and if I have to tow it down to Florida to race well ill just do it lol
Old Aug 13, 2012 | 08:58 PM
  #79
Camaro9969's Avatar
Stripped off the powdercoating and polished the wheels a lot of work but came out nicer than I expected
Before
Stripped
After
All gauges wired up
Old Aug 13, 2012 | 09:34 PM
  #80
Sales@Tick's Avatar
Just think now you can say Martin@Tick helped me spec my build out!
What diameter converter did you end up with again? I think you'll like it a lot whatever it is.
