LQ4 S480 Build
Old Aug 10, 2013 | 09:17 PM
  #781
Camaro9969's Avatar
Originally Posted by White.Lightning
I want to paint my engine bay so bad, but the engine is in the car so it will have to wait.
Looks good!
Ya I dont recommend spinning a bearing just to paint the engine bay.
Old Aug 10, 2013 | 10:21 PM
  #782
78buturbo's Avatar
Looks good Doug but you ain't leaving any work for the winter lol
Old Aug 11, 2013 | 08:02 PM
  #783
Camaro9969's Avatar
Oh I wish haha building a forged 370, got a couple guys bringing their cars to work on over winter. Have a 69 Camaro to finish up also a 96 M3 LS swap. I have my hands full
Old Aug 12, 2013 | 11:50 PM
  #784
78buturbo's Avatar
Thumbs up
Yeah you do but it's fun work, I would like to see your car when you get it finished up sometime oh that welder is still going strong
Old Aug 13, 2013 | 09:29 PM
  #785
Camaro9969's Avatar
Old Cast Manifold meets New Stainless V Band
Old Aug 13, 2013 | 09:38 PM
  #786
mrstepheneades's Avatar
How's that cast tig up lol?
Old Aug 20, 2013 | 09:49 PM
  #787
T76s10's Avatar
how did you tune your tu2 cam in hp tuners? im having trouble tuning mine. im pulling around 11" vacuum at idle. if you could share some of your info that would be awesome
Old Aug 21, 2013 | 05:08 AM
  #788
Camaro9969's Avatar
This was my first car I've tuned it took me about 10+ hours to get it to idle where I wanted. Tons of reading on HP tuners forum picked up Master Efi Tuner which helped. And another member called me from TX and helped me understand what needed to be done. Also You need to make sure your injector data is correct also are you SD? MAF? I could ask a thousand questions. Where are you having troubles?
Old Aug 21, 2013 | 10:12 PM
  #789
T76s10's Avatar
Yes im in sd. My injector data is correct im just wondering how you tuned your airflow tables to account for the larger cam. My timing is all over the place and im having tons of knock at idle. It backfires and has absolutely no throttle response. My afr isnt hooked up but im guessing its lean. Just wondering what tables you messed with to tune your cam
Old Aug 21, 2013 | 10:18 PM
  #790
Camaro9969's Avatar
I would say something else is wrong because even when I had a stock tune it ran fine just was rich. Sounds like cam timing. Have you flashed it back to stock and see if it runs alright? I changed ve, idle trims min pulse width etc .....
Old Aug 21, 2013 | 10:23 PM
  #791
Camaro9969's Avatar
Got the motor in Friday fired it up and sounds great way more oil pressure than the last one. Also more compression 162-165 per cylinder old motor was 153-155.
Also got my turbo back again with a new PTC 9.5" converter. And got the trans refreshed
Old Aug 21, 2013 | 10:54 PM
  #792
Bout ready to go 9.50s now ain't ya lol!!!!!
Old Aug 22, 2013 | 07:44 AM
  #793
douglee25's Avatar
BooYah!
Old Aug 22, 2013 | 08:26 PM
  #794
Camaro9969's Avatar
Just got these in today Christmas in August lol
Will be driving again tomorrow just waiting for my case of ams oil and ill bolt the Turbo on check the tune and give it another shot
Old Aug 22, 2013 | 08:35 PM
  #795
Sarg's Avatar
Pretty....jealous!
Old Aug 23, 2013 | 12:36 AM
  #796
Constant_project21's Avatar
Friend showed me a video of this car the other day, glad I found the build thread! Awesome car, keep up the good work! One of these days I'll get to do my stock block project.
Old Aug 23, 2013 | 01:25 AM
  #797
NightmareTA's Avatar
Looking good man! Just saw you had a build thread on here. Glad to see it will be street worthy again shortly!
I currently have mine all ripped apart and will hopefully be in the reassembly stages all day tomorrow (Friday). Maybe even have it running again for the end of the weekend. I'm not letting this damn 5.3 die until it REALLY grenades!
Old Aug 23, 2013 | 07:07 AM
  #798
Camaro9969's Avatar
Thanks man def pumped to start driving it again.
Your making some quick work with the tear down. If you need some help text me and ill swing by.
And with your mild tune and lower boost its not going to explode anytime soon lol before the end of the year I say lets crank it up 20+
Old Aug 23, 2013 | 07:10 AM
  #799
Camaro9969's Avatar
Thanks it definitely keeps me busy though.....
Old Aug 23, 2013 | 08:51 AM
  #800
Blackpanther99's Avatar
Moving quick!
