LQ4 S480 Build
Old Oct 11, 2013 | 09:25 AM
  #961
Camaro9969's Avatar
Originally Posted by mike13
I wish I had that kind of skill, what's your background to becoming such a skilled fabricator?
Thanks! Its my buddy Ed who does the welding and fab work we both are getting the business together and its been going well. He went to Hobart institute of welding technology and soecicalise in bio pharm stainless and asme b31.1 steam and pressure vessel certified.
Old Oct 11, 2013 | 09:29 AM
  #962
Camaro9969's Avatar
Originally Posted by RedRocketZ28
Send one of those my way!
Haha would love to. Pm me if you ever want one for your car
Old Oct 11, 2013 | 09:30 AM
  #963
Camaro9969's Avatar
Originally Posted by MUSTANGBRKR02
Looks awesome.
Thanks!! Wait till we get going on your car!
Old Oct 11, 2013 | 09:32 AM
  #964
mike13's Avatar
Makes sense, I had a long time friend who passed away, his work looked as good he was a union pipefitter worked in the nuclear field. Awesome work, to bad it's going to be buried below the turbo.
Old Oct 11, 2013 | 10:12 AM
  #965
mrstepheneades's Avatar
I knew whoever was doing those welds had to be a pro. They so Purdy lol lol.
Old Oct 12, 2013 | 09:36 PM
  #966
Sales@Tick's Avatar
No mention of the "secret weapon" part yet?
I'm disappointed Doug...I thought we were bro's.
lol
Old Oct 13, 2013 | 06:52 AM
  #967
Camaro9969's Avatar
Haven't updated about the motor in a while. Not to go into too much detail but picked up the 370 from NC and looked it over a little before just going for it, noticed right away the cam bearing were wiped out then since i saw that had to pop a cap off. Those were even worse. So dropped it off at RAD Auto Machine a shop local to me and it just got worse. Crank was bad the grooves in it were bad enough that it couldn't be turned. Then i was told that the bore was undersized. A shop Local to Bill assembled and did all the machine work but they did not do a good job measuring, cleaning, or even checking their work. But anyways all is good now Motor go redone to the correct clearances also took my old crank out and had them install and balance everything. Did Coated cam, main, and Rod Bearings, while in there got ARP Main studs done, figured might as well lol. Thanks again Bill appreciate the help with this. So the New Set up is a forged 370 Weisco pistons -11cc pistons Compstar Rods Stock crank Still same stock heads and a new Tick Performance Cam Spec'd by Martin, highly recommend dealing with him very helpful and always available to answer any questions thanks again! Specs are .229/.237 .627/.610 114+6
Here are some pics
Coated Bearings
POWER!!
Also sent my converter back to PTC to be tightened so between the 370, cam and converter i should pick up a little MPH LOL
Old Oct 13, 2013 | 06:57 AM
  #968
Camaro9969's Avatar
lol
haha well if i mention all my changes there's no secret
Thanks man for your help this thing should fly!!
Old Oct 13, 2013 | 07:31 AM
  #969
MUSTANGBRKR02's Avatar
Glad we got that engine straightened out. Now all we need to do is get you to put some miles on that thing so you can go see what it will do.
Old Oct 13, 2013 | 04:48 PM
  #970
Sales@Tick's Avatar
I have no doubt in my mind that this car will use every bit of it's 8.50 certification.
Old Oct 14, 2013 | 08:36 AM
  #971
Camaro9969's Avatar
Thanks man i hope so! I do need a chute ASAP! lol
Old Oct 14, 2013 | 10:24 AM
  #972
150+mph...................YES!!!!!!!!!!!!!!!!!!
Old Oct 15, 2013 | 11:38 AM
  #973
Agent_Orange_Shuvel's Avatar
This thing is gonna scream with the new combo! Can't wait to see it back on the track.
Old Oct 15, 2013 | 09:29 PM
  #974
oscs's Avatar
what size intercooler did you go with? do you know the CFM rating? The only one i can find to fit in my swapped car is 700 CFM..
Old Oct 16, 2013 | 07:10 AM
  #975
Camaro9969's Avatar
Me too man!
Should be running tonight as long as my converter comes in today as planned. I am doing a track rental next friday so i'll be out all day hopefully all goes well
31x12x4 not sure the CFM it works OK I do need a better one though at this point.
Old Oct 16, 2013 | 08:53 AM
  #976
You gonna turn that boost up now that its forged lol? I wanna see you get 150+.
Old Oct 16, 2013 | 11:45 AM
  #977
oscs's Avatar
Me too man!
are you gauging this by the air temperature?
Old Oct 16, 2013 | 10:01 PM
  #978
Camaro9969's Avatar
I shouldn't even have to touch the boost to get in the 150 range but of course ill be turning it up or else I would of done another stock motor
Old Oct 16, 2013 | 10:05 PM
  #979
Camaro9969's Avatar
I watch my IAT's during my runs I can tell by how much it rises by the end of the track its not efficient. Yes meth would help but a better intercooler would be a great upgrade right now. We will be making one over winter
Old Oct 18, 2013 | 04:01 PM
  #980
Sales@Tick's Avatar
A little birdy told me Camaro9969 changed camshafts. To one of those Tick Performance cams that don't work...how will it ever run as fast as it did before with 10 less degrees duration and 6 degrees less overlap?!?!?!
