LQ4 S480 Build
Doug you have some bad luck lol. If its not engines its the car body lol. Guess hood come unlatched. Mine makes me a little nervous at high speeds. Looks like Flash's car when he was racing that lambo. We have same hood latches. They hold good but hood just flexes in the wind. Wouldn't want this happening to me Doug.
Car sounds a lot better IMO. Try pulling some timing out of it next time instead of leaving with less boost. Get the compressor and turbine speed up so it's there when you leave. You can ramp timing back in the motor a lot faster than boost.
How much boost did you leave on when you went 9.2?
The 9.2 was 13psi. Now can't launch more than 8-9 but again I have lowering springs still enough to yank the wheels. Will get it better once I have the right controller and rear shocks
As for sound personally I like the tu2 better but its about performance and this cam feels more NA ish where it has better torque down low
