LQ4 S480 Build
Took the car out last night there are a lot of things to work out this time around. New rear viking shocks travel limiters up front and this co2 controller. So first pass blew the tires off and by the 3rd it got a little traction but i think i need to adjust the limiters so i'll give it another shot again sat. Controller was giving me issues wouldn't build more than 13psi for some reason so i'll contact Randy today to see if he has any suggestions but the car felt real strong for 13psi and only 14* timing on straight pump gas
I will switch to viking coilovers all around for next year but ive just got too much money into this year already.
Thanks man!!
Got a new intake on and the car is making more power than it ever has. Actually shocked the hell out of me this is a 17psi 12.5* timing pull straight pump haven't touched meth yet.
17psi Pull 370 S480:
Glad i found it also it was a massive leak just hope the turbo is ok for now i'll make a few passes and check it again.
I'll def give you some numbers after we get it squared away but now thats what is going on right now it hooks then unloads but it was down a ton of power so this week i'll finally get some good data.............You have limiters up front????
