91' Notch 383/PT88 in time for TX2K12
#63
Thanks man!!! I was not expecting to win, but things just kinda fell into place.
Thanks . I have so much editing to do, I might just give all my vids to Redmaro and let him edit them lol.
Here are all the numbers from the 9.20 pass
1.54 60ft
6.07@124 1/8th
9.20@155 1/4
And did your car have a cowl hood and bead locked rear wheels?
Your car is gorgeous man!!! It was great meeting you and a blast getting to race such an awesome car!! I had a list and your car was top 3 to run lol.
1.54 60ft
6.07@124 1/8th
9.20@155 1/4
#67
It went 9.91 on low boost then turned it up and broke lol coasting from 1/8 on it went 9.66 at 122 haha went 124 in the 1/8 no 2step or trans brake its just a stock bottom end lq9 with a gt88 were gonna get it fixed and make some more passes in kc but are track closed down so probably go to topeka or stl
#68
#78
How can you measure slip? And if it is slipping too much does that mean I need a tighter or looser converter?
#79
With the info u gave me I got 11.82 percent of slippage.
http://www.baycityrides.org/slippage.php?mode=calculate
Think of it this way, a well built converter may slip 4-5%, if yours slips 6-7% higher, you are baking the fluid, cooking the band, and compromising the clutches, and giving up mph and ET.
#80
Also on the dyno when going from low boost to high boost, the dyno read a significant loss in MPH at redline in 3rd. It was like 140mph on low boost and 125mph on high boost.
