only a tenth away from my goal :)
Old Mar 21, 2004 | 04:28 PM
kp's Avatar
kp
Default only a tenth away from my goal :)
Took advantage of some cool weather today (50 degrees) and hit the local 1/8 mile track. Ran a 7.09 @ 98 with a 1.605 60' with the cutout open, 7.11 @ 97..7 (1.611) with the cutout closed (gotta love them dual/duals ). I cant wait to get this down a 1/4 mile track but I had trailer problems this weekend and didnt want to drive the car 400 miles with no o/d
3550lb raceweight, 440rwhp (converter unlocked), 7.5psi @ 6500rpm, 100% stock motor except for 918 springs and FLP headers. A/f was 11.2 to 11.0 through the passes so it has a little more in it but its safe, next time I'll lean it out with some 100 unleaded and see what happens
I would lke to hit 6.99 in the 1/8 and 10.99 in the 1/4 - its getting there, I really need to get the stall raised a bit. I know its nothing compared to the big HP guys out there but I want to bracket race this thing all year on the stock motor In ten passes today it ran within .04 so thats not bad for a blower car. Even got the wheels up every pass, sorry for the bad quality pic but my scanner is dead and I just took a pic of the pic..
Old Mar 21, 2004 | 04:41 PM
BIGBOS's Avatar
Good to see you got a nice consistent setup running....
I can't wait to put consistent along w/my setup....
I think you can crack off some 11.1/11.2 passes.....
Old Mar 21, 2004 | 05:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sweet you are so close to the 10's...
Was the track not hooking or do you need more converter?
Old Mar 21, 2004 | 06:16 PM
S_J_H's Avatar
Thumbs up
nice runs! Your doing excellent for that low amount of boost with a stock motor!
Old Mar 21, 2004 | 06:53 PM
Hardtop's Avatar
Nice pic, and great times with a stock motor and blower.
Bruce
Old Mar 21, 2004 | 07:09 PM
kp's Avatar
kp
Need more converter, car dead hooks but I am getting the same 60's with my other car with a 3.23 and a ST3500. Its a TP4200 but was made for a pretty good sized stroker, it flashes to ~3500 or so at the starting line so upping it a couple hundred rpm sure wouldnt hurt the 60' - but then again I may start blowing the 10.5" ET streets away on marginal tracks with more converter. The 60' clocks at this track seem a little slower then some of the others around here so until i get to a real NHRA track I cant say for sure.
Probably easier to just lean it out a little on better gas and pick up 10rwhp or so but this poor motor has 270 head/cam/M6 leaving at 6000rpm passes from last year and a lot this year with the blower so I dont want it to go
Old Mar 21, 2004 | 07:51 PM
2001 Pewter WS6's Avatar
Restricted User
You 'll get there... Keep it up and good luck... Try dropping the Y-Pipe and running the headers with just the extensions....
Old Mar 21, 2004 | 08:00 PM
kp's Avatar
kp
tried that on the dyno (the FLP y-pipe gets awefull small at the collector) but it really didnt change anything. It seems like no matter what I do with the exhaust, MACs, FLPs, open headers, open cutout, nothing ever changes - thats the advantage of making no power I guess But I do appreciate the deal on the FLPs, my main reason to get them was so I could put cats on the car when I cruise it and they worked out great..
Old Mar 21, 2004 | 08:06 PM
Restricted User
That the nicest thing about them Change from off road pipes to Cats in about 10 minutes...
Old Mar 21, 2004 | 08:09 PM
LS1Tech Co-Founder
You think the tires can handle another 400 rpms?
Old Mar 21, 2004 | 09:04 PM
kp's Avatar
kp
On a well prepped track yes, on the crap local tracks no. I could always switch to a full slick. Now that I have an extra set of street tires/wheels i may do it when these wear out.
I have to screw the rims anyhow, the tires are moving about an inch now on every pass, so I may as well switch to ET drags I guess. I'd like to try more stall but I really should get some weight out of it - that would help the 60's more then anything probably. I just hate to overstall it and lose MPH plus make it drive looser then it already does. I just think the car should be ETing a little better for an automatic trans 98mph 1/8 and this track is not very generous with the MPH..
