Another E85 thread
Old Feb 26, 2012 | 07:09 PM
Ryans99ls1's Avatar
Yeah im not going to be running timing anywhere near 19 degrees. Your AFR doesnt seem too far off from what ive read though.
Whats your motor setup?
Old Feb 27, 2012 | 02:52 PM
RexDiablo's Avatar
The one i used last year was a stock ls1 2002 with a mild cam (dont know what it was).
Had a Garrett GT42 turbo with 0.65 bar (9.4 psi) boost. 60 lb injectors and two bosch pumps and E85
Same engine has been used a couple of years with boost in my track-car. im amazed how much beating it took before it died.
EDIT: it didnt die because of boost. The waterpump stopped and the engine overheated. A piston got stuck and crushed everything.
My new setup is the same but with forged piston and rods with ported 317 heads and 9.8:1 compression. Dont know how that will work yet but i hope it will be reliable as well.
