p1sc 5.3 blazer
Any info would be great.
Thanks,
Kory
Kory
What are you running for exhaust. I built 1 3/4"lt headers for my truck. will also be running 3" duals.
Should be fun.
Kory
Yeah man dont give up on it that quick just because you have the usual belt slip.... You need to check your belt alignment, tighten the F out of the belt..... Get it as tight as you possibly can....then go a bit more.
Unless you can go to a different bracket setup with different tensioners/idlers for more belt wrap, the best you can do is get the belt super tight. You can easily make 10-12 psi on a 6 rib once you get the tension/belt wrap right...
Youre this close to getting it fixed right, why give up now? C'mon man tough it out... You can EASILY make 700rwhp with a P1sc but you have to get the belt slip resolved.... Does it not feel good to you at 5500/10psi before it loses boost?
Keep at it....You'll have a truely "one off" ride with the blower on it.... EVERYBODY it turboing stuff...atleast you did something different...
A lot of the aftermarket blower brackets for C5/6s have multiple idler pullies, and one closer to the balancer to increase wrap on the balancer...
Surely the truck kits have something similar... you may have to make something though..
