Nasty BOV for D1SC video inside...
http://www.youtube.com/user/FahadZO6#p/u/6/D8rq7QglIc0
http://www.youtube.com/user/FahadZO6#p/u/7/muEfMN5DQ90
http://www.youtube.com/watch?v=a_IZw5Ur-zM
Didn't hear much cam lope are you running stock internals?, I highly doubt with that much boost could be the video quality.
http://www.youtube.com/watch?v=2vACDl_SQQ0
http://www.youtube.com/watch?v=lFjqrg_1-tM
Blow off valves are for Turbos Only. - end of story. If someone is using a blow off valve on a belt driven FI car, they dont understand how they work, and are hindering optimum performance, fuel economy and longevity.
Bypass valves or Surge valves are used with Belt driven blowers, such as a centrifugal like Procharger.
They work differently and have their own applications.
Centrifugal type blowers - Even with relatively little increase in engine load at low throttle positions, air is still being pumped by the compressor on a belt driven system, unlike turbo, where boost is non-existent.
With a Belt driven system, this pumping volume is still greater than the engines airflow requirements at idle and low loads, so pressure builds between the throttle blade and the compressor. The added pressure on the compressor blades creates drag on the accessory drive that can make idle control difficult amongst blade stresses, more hp to continue the turn, and lower fuel economy.
A BOV at idle or high vacuum in the manifold will NOT let this pressurized air out where as a surge valve or bypass valve is open during vacuum and part throttle. Even with modification of the spring action of a turbo BOV which is set for a certain pressure level to allow air to escape, you will not get a proper response throughout all engine loads vs RPM. You may make it work for idle, (ex. 35Kpa Vac) but it will not work at 3000rpm with 22% TPS (throttle), real world talk
Leave the two alone and only use the appropriate device for your application.
