Cam question. F13 and lm7
As the title says, I'm looking for some insight. I have an f13 that I used in my ls1. But that motor bit the dust. Would I be able to use this cam in an lm7 5.3 motor? I will be putting my 243 heads and the turbo back on. T70 and looking at 10+ psi. Also have the patriot gold dual springs. I'm thinking this cam may be too big, but would like to get other opinions.
I actually was thinking of running that cam in my LM7 about a year ago. I called Futral asking if it would work. They said f13's are meant for the bigger cubes(5.7's and 6.0's). It would work but the power would be too high in the rpm's and would have to run a high stall converter. You being turbo'd might be a different story though. You can always call Futral.
