Water/Meth kit trunk mount. Will this be track legal?
I wanted to mount this in my engine compartment area but it will be too close to heat no matter what I do. I have enough hose to mount it in the trunk. This is the location I chose to help keep my weight more equal in all four corners with me in the car. I have not mounted it yet. It is just sitting in there. I just wanted to make sure that by mounting it there I won't have any issues passing tech at the tracks.
Any suggestions or comments are appreciated.
Thanks. Good to know.
The only place I have is on my firewall. The turbos are where my battery was. The downpipes come to close to it on the firewall. The pump and the tank would be closer than a 1/4" to the down pipe. Just didn't want to take a chance that close to the hottest area in my engine compartment.
Since you can use winshield washer fluid as the fluid in your water/methanol system, I can't believe anyone would care where you mount it. You could even simply tap into your winshield washer reservoir as the source fluid and still use your windshield washers.
... Larry S.
... Larry S.
... Larry S.
... Larry S.
Thanks for the help all.
Good to know. I did my first long trip today. I drove it over 3 hrs roundtrip on a tank of fuel. Averaged 17mpg! Only jumped on it about a half dozen times. When I got home it didn't look as though I had used any of the water injection. lol I know it worked though. The light would come on just like it was supposed to around 12 psi of boost.
We played with the tune when I got there. I am trying to remember but I think we added a little timing in the area that I will launch off the transbrake from. I think from 3000-3600 we added a little timing back in. Something about not blowing the flame out while on the transbrake and 2 step.
I hope that my first tnt on Sunday doesn't get rained out.
