Spoolin performance altenator bracket
Old Mar 5, 2012 | 11:31 PM
jt76's Avatar
Default Spoolin performance altenator bracket
Does anyone have pictures of one of these installed? I cannot figure it out at all. The plastic cover on the back of the alt hits the top of the head and valve cover ugh!
Old Mar 7, 2012 | 12:32 AM
1sicws6's Avatar
the owner is a buddy of mine i'll have him chime in
Old Mar 7, 2012 | 10:13 AM
TurboZ28408's Avatar
the rear cover needs to be removed
http://s138.photobucket.com/albums/q...elo%20bracket/
Old Mar 7, 2012 | 11:22 AM
607motorsports's Avatar
I just installed one on my car during my turbo build. I was only able to use the upper bracket unfortunately but yes you need to remove or trim the back black plastic cover on the alt to make it fit.
Personally I did not like the look without the cover completely off so I trimmed the protruding squared off piece from the back of the cover off with a dremel. Once I got it all installed it honestly looks stock. I don't have a pic on hand but I can grab one for you if you want.
Old Mar 7, 2012 | 12:59 PM
jt76's Avatar
Yes if it isn't too much trouble I would really like to see a picture of how you trimmed the cover. I eventually figured out that the cover had to be removed but I dont like the back of it exposed
Old Mar 7, 2012 | 03:22 PM
No problem man I will grab one for you from the back side. Here is a shot of what it looks like from the drivers side and front, if you didn't know you would never know I trimmed the back plastic.
Old Mar 8, 2012 | 09:55 AM
Here ya go man, this is all I did to make mine work.
Old Mar 8, 2012 | 12:44 PM
jt76's Avatar
thank you kindly sir! where did you mount the idler pulley?
Old Mar 8, 2012 | 02:41 PM
I've got the PTK kit (a true one from another fbod forum) so I had to keep my idler puller down low but just remove the alternator. Unfortunately I didn't realize the lower Spoolin Performance bracket wouldn't work for me when I originally bought it so I ended up putting my tensioner in the stock location under the alternator. It all works pretty well now but def took some figuring out LOL.
Old Mar 8, 2012 | 02:56 PM
what belt did you use ? so you just used the upper spoolin bracket and tensioner in the stock location ?
Old Mar 8, 2012 | 03:19 PM
Yes, upper spoolin bracket, stock idler location, stock tensioner location (had to slightly shave the backside of the tensioner bracket slightly and a 76" belt is what I have on my setup.
Old Mar 8, 2012 | 04:06 PM
bigassogre's Avatar
can somebody please give me the length of the sleeve that goes around the bottom alternator bolt? imbgoing to make it all myself neway. just wanna take some guesswork out
