two step with auto?
Old Mar 6, 2012 | 05:17 PM
mechanix565's Avatar
Default two step with auto?
is it possible to set a two step up with an auto trans i wanna start boosting at the line my stall is 3600 not sure if its doable.. through a pretty much bullet proof 4l65e.. single turbo cammed 4.8 w/ some head work 76mm turbo @20psi just wanna get maybe 5-8 pounds at the line for a hard launch. i could use the signal wire on the brake switch instead of the clutch i just dont no how it would work or if would just push through the brakes.. truck is awd btw..
Old Mar 6, 2012 | 06:35 PM
dschmittie1's Avatar
I think your going to have an issue pushing though the brakes with out a T brake. how hard can you push it on before it pushes with the brakes now?
Old Mar 6, 2012 | 06:51 PM
1BADAZZSS's Avatar
What year truck? Hydro boost conversion is only way to go. I did that on my '04 silvy I had. Could launch 5-10# and never push through the brakes
Old Mar 6, 2012 | 09:03 PM
1BADAZZSS's Avatar
Old Mar 6, 2012 | 10:12 PM
dville_gt's Avatar
i could build ~7psi on the footbrake and a 2 step @ 3500rpm 100% tps without pusing through the brakes, but my stall is probably a lot looser then yours.
Old Mar 7, 2012 | 12:21 AM
buick_lsx's Avatar
Just depends on combo...mine makes 10 psi footbrake at 2800
Old Mar 7, 2012 | 12:25 AM
FasTimeSS's Avatar
It should blow through the converter if u have a trans brake wire it to that, thats how i have mine and it works fine
Old Mar 7, 2012 | 08:09 AM
Sarg's Avatar
Hoping to do this as well. If not, I guess I will get a tbrake.
