turbo guys a newbie needs help
Old Mar 9, 2012 | 06:55 PM
1bad99's Avatar
Default turbo guys a newbie needs help
Ok guys, I've decided to go with a rear mount setup instead of front. And need some help and advise. What's a good oil pump to use for the turbo? It's a precision 70mm if that helps. I'm trying to get all my ducks.in a row, so any thing you guys can assist me on would be great. 1St turbo so need Lil help. I'm sure I've got more questions. Thanks guys.
Old Mar 9, 2012 | 08:08 PM
1bad99's Avatar
Other than fuel parts, is there any parts or accessories anyone can think I'll need as far as oil lines, fitting, ect anything you guys can tell me, suggest will help. If y'all have question please ask, I'll answer what I can. I'll be running a A2W intercooler w/ heat exchanger.
Old Mar 9, 2012 | 08:15 PM
Burken01's Avatar
Im in the same boat as you, new to turbos...
read all the stickies up top^^^
and search "Turbo ls1" and youll see alot of combos that people have posted, front and rear setups..
goodluck
Old Mar 9, 2012 | 08:35 PM
1bad99's Avatar
Thanks Burken
