?? oil pressure sensor??
Old Mar 10, 2012 | 02:47 PM
lbm13186's Avatar
Default ?? oil pressure sensor??
so i have a 2000 trans am and i purchased a iron block for it because im putting a d1 procharger on it and i have it all installed and trying to put the alternator into place and it look like there is a oil pressure sensor in the way of where the alternator goes. was wondering if anyone could help me out here
any info would help thanks
Attached Thumbnails ?? oil pressure sensor??-img_1235.jpg   ?? oil pressure sensor??-img_1236.jpg
Old Mar 10, 2012 | 04:40 PM
TermnEatr's Avatar
That's where a plug goes not a sensor
Old Mar 10, 2012 | 05:07 PM
lbm13186's Avatar
so is that a secondary oil plug or something? and can anyone confirm this... i guess if that is the case the guy that built the engine for me, one of his techs must of just put it there or something... idk haha just trying to get this thing started again
thanks for the help
Old Mar 10, 2012 | 05:16 PM
TermnEatr's Avatar
The oil pressure sensor goes threads in behind the drivers side of the intake that's a oil galley plug I just went and looked at my block Google ls1 oil pressure sensor location
Old Mar 10, 2012 | 07:27 PM
lbm13186's Avatar
thanks a lot man
Old Mar 10, 2012 | 08:10 PM
68 SS's Avatar
You may want to drill and tap the hole in the block that is missing while you have it all apart cause you are going to need it when you install the procharger. As said above the oil sending unit is in the wrong location
Old Mar 10, 2012 | 10:53 PM
lbm13186's Avatar
what hole are you talking about, i didnt know that i needed to drill into the block for anything?
Old Mar 11, 2012 | 01:17 PM
lbm13186's Avatar
can anyone conform that is a place where a plug should go and does anyone know what 68 ss is talking about when he said you have to drill a hole for the pro charger??
Old Mar 11, 2012 | 04:24 PM
TermnEatr's Avatar
I'll get pics later
Old Mar 11, 2012 | 08:48 PM
68 SS's Avatar
There is a boss in the block on the front right above where the oil sending unit is installed in your pic that is not drilled/tapped, on an iron block that is where one of the bolts for the procharger brackets bolts up.
The hole where you have the oil pressure sending unit is for a fact supposed to have a plug in it. The oil sending unit goes on the top of the block behind the intake.
Old Mar 11, 2012 | 09:14 PM
TermnEatr's Avatar
Op if u want pics pm me Ur number or address
Old Mar 12, 2012 | 06:19 PM
lbm13186's Avatar
my email is lbm123123@aol.com sorry i forgot what my pm was
68 ss is there any way that you can send me a pic of where i need to drill the hole, or should it say in the install manual or something or no since it would be there on a reg alum block???
Old Mar 12, 2012 | 07:25 PM
TermnEatr's Avatar
I'll send u both dude
Old Mar 12, 2012 | 07:59 PM
lbm13186's Avatar
thanks a lot man, just new to this and i dont wanna mess it up at this stage and would like to make it easier on me and one of my buddy's who's a audi tech
Old Mar 12, 2012 | 08:43 PM
TermnEatr's Avatar
Pics sent
Old Mar 12, 2012 | 09:10 PM
lbm13186's Avatar
thanks TermnEatr those will help a lot.. i was wondering if any one knows the size of the bolt that goes into that hold for the procharger bracket bolt
thans guys
Old Mar 13, 2012 | 03:22 PM
lbm13186's Avatar
thans guys
Old Mar 13, 2012 | 09:13 PM
68 SS's Avatar
If I remember correctly it is a 10mm x 1.5 I will check tomorrow and let you know for sure.
Old Mar 13, 2012 | 09:59 PM
lbm13186's Avatar
thanks man just wondering so i can get the right stuff over here to do it
