Power steering relocation kit is FINISHED!!!!
Old Mar 10, 2012 | 09:00 PM
ModularTurbo's Avatar
Default Power steering relocation kit is FINISHED!!!!
Check it out it's finally done!
Here is a link to this product in our online store:
http://vtsql.gkvbf.servertrust.com/L...t-p/cbrpsr.htm
Old Mar 10, 2012 | 09:06 PM
Bobsmyuncle's Avatar
Shipped price?
Old Mar 10, 2012 | 09:14 PM
The link above the pic is to my online store you can get pricing and shipping there.
Old Mar 10, 2012 | 11:07 PM
67RSCamaroVette's Avatar
About time, Rob! I'm assuming this won't work with an EWP setup?
Old Mar 10, 2012 | 11:11 PM
westtexasbuff's Avatar
Are the lines required or can you use the stock lines?
Old Mar 11, 2012 | 06:27 AM
98Camarod's Avatar
There's an option to remove the line kit on the site if you already have your own. I would assume that the stock lines wouldn't work either. You have all that heat right there with the truck manifolds and turbo, you wouldn't want to melt through your lines.
Old Mar 11, 2012 | 07:31 AM
formula98ws6's Avatar
Will belt that comes with your alternator relocation setup work with this. Or if I buy this and your alternator relocation. Will I need a different belt than what comes in alternator kit.
Old Mar 11, 2012 | 09:13 AM
You will need a different belt if you have our alternator kit.
I haven't tried it with an EWP setup yet but I pretty sure it will work.
You must use our power steering line kit. But I can't completely rule out someone else's line kit.
The stock lines will NOT work.
Old Mar 11, 2012 | 11:11 AM
I've done some checking on the EWP's
The pump must have a idler pulley like Meziere Part# WP319.
The only thing that may change something is the thickness of the pump.
This can be easily accounted for with a length adjustment of the idler pulley post
on our bracket.
If anyone needs to run a EWP I will discount one kit $50.00 to the first guy to ship us his EWP so we can do a fit confirmation.
Old Mar 21, 2012 | 11:07 PM
We will have more in stock in a few days
Old Mar 22, 2012 | 09:39 AM
venom ws7's Avatar
Great work & products
Old Mar 22, 2012 | 10:06 AM
tim99ws6's Avatar
Looks like top notch stuff!
Old Mar 22, 2012 | 11:34 AM
turbocamaro125's Avatar
Ordered one lastnite....and Rob called me back like 5 minutes later to check to see about the order....at 10:30pm....you cant BEAT that customer service!!!!!!!!!!!!
Thanks Rob
Old Mar 22, 2012 | 11:44 AM
Deezl SS's Avatar
I have a question Rob. Would it be possible to run a longer stainless line on the one side so I would only have to use a 2" section of rubber hose? I'm worried about heat on my setup melting that hose.
Old Mar 22, 2012 | 05:37 PM
Just use a heat barrier or wrap then.
Or lengthen our line with your own fittings.
We can't make a longer line just for one person without it costing big bucks.
We have these hydraulic hoses specially made in large quantities to keep the price down.
Old Mar 22, 2012 | 07:44 PM
FasTimeSS's Avatar
do you happen to know the size of the fittings that are in the actual ps rack?
thanks
Old Mar 25, 2012 | 02:03 PM
Adam86's Avatar
Ordered this a couple of weeks ago and it arrived promptly. Thanks again Chris for helping me out! The bracket fits like a glove and it made everything fit together on my car perfectly. Bought this because the crossover I was using on my turbo setup was rubbing against the belt and this took care of it. Didn't need the idler pulley because my alternator is in the stock location, but I'm sure I'll find a use for it
Be aware that if you use this kit with all other accessories in the stock locations, you will need a ~2" LONGER belt for your system.
Thanks again to the MT guys!
Old Apr 20, 2012 | 02:27 PM
the_reaper's Avatar
Rob just a quick couple questions I am doing a ls jeep swap and dont have a pump yet,
1. What part number pump should I use
2. Will you kit give me everything I need to mount the pump to the head with the exception of the pump itself. if not what else would I need. There seems to be a triangle looking piece on the head from looking at your pictures that is not listed with the kit.
Thank you
Old Apr 20, 2012 | 04:44 PM
Firehawk441's Avatar
The part you're asking about is an OEM F-Body P/S bracket
Old Apr 21, 2012 | 11:58 AM
denmah's Avatar
Moderator
i wonder if this will clear g8 manifolds, they dont go out as far as the truck ones but are tighter and neater to the block.
